Camshaft position for timing Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
tango_1000
Year and Model: c70 2007/ C70 2011
Has thanked: 9 times
Re: Camshaft position for timing
Post by tango_1000 »
This part of my problem is fix. I put back the belt and turn the crankshaft together with the camshaft wheels, so this is solve.
I took out the air filter housing, computer, and I got to the starter which I also took out so I have direct access to the plug. I inserted the crankshaft alignment tool.
The problem now is that turning the crankshaft just get to a point that get lock/stuck, going clockwise. Then I turned counter clockwise and about half round will also get lock/stuck in that direction, I didn't want forced it. I had the camshafts lock with the camshaft tool but I also took it out in case that had something to do with it, I can put them back later.
Any help appreciate it. Thanks
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
The gear should only fit on the crankshaft one way. There are splines inside the gear, and corresponding splines on the crankshaft, and the gear will only fit on in one orientation and fully seat to the bottom. Other orientations it may go on only part way, but only one where it will seat all the way. Once you find that, you should be able to double-check using the crank tool described above - the marks on the gear should align with the marks on the oil pump once the other part is installed.
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
tango_1000
Exactly. The gear goes in only in one point. So I locked together the crankshaft and camshafts. put the belt and everything works great...Thanks
Horszi42
Year and Model: 2005 S40
Post by Horszi42 »
Hello Guys, I still don't have the camlocking tool for T5 so I would have a question. As I know the pins on the two sides are parallel but they are on different planes. Could you please confirm it?
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Yes they are on different planes. That is what keeps one from getting the cams 180° out of phase.
Horszi42
Post by Horszi42 »
Dear RickHaleParker, thank you for your quick response!
Rvolvos
Year and Model: 2006 xc70
Has thanked: 73 times
Been thanked: 23 times
Post by Rvolvos »
RickHaleParker wrote: 24 Oct 2019, 04:22 Blue is the Crankshaft alignment tool. Inserts in alignment hole located under the starter. Starter removal required.
Green is the Camshaft alignment tool. Backside of cams.
Yellow is used to hold the front of the camshafts to the camshaft cover.
Browns are the Camshaft cover tools. Use to maintain even pressure on the camshaft cover when removing and installing the camshaft cover so that one does not warp the cover. The cover is line matched to the head at the factory. If you damage it you cannot just go and get another one. You would need to have a machinist work another one to match the head.
Sorry don’t want to highjack this thread, but I did have i question regarding the blue crankshaft alignment tool.
I did test this on 2 different B5254T7 engines, fully inserted and crank aligned, but was still able to rotate the crankshaft. This tool looks identical to this set.
Any idea what I may have done wrong?
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2011 C30 T5 M66 105k Totalled RIP
2006 V70 2.5T 184k RIP
2011 C30 T5 AW55-50SN 99k sold
Horszi42
Post by Horszi42 »
Hello Guys again,
so regarding the cam locker tool does someone have a drawing with the dimesions? I found one on web with cyrill letters but as I think it's not the proper one. The most important would be the position of the step/berm on the cylinder's surface. According to the found document the widht of the step is 4.4mm, the height is 5.5mm and one of the side of this step is on the center-line of the cylinder.. On the camshaft the groove is in a little bit different position. Thank you for your help in advance!
RickHaleParker
Rvolvos wrote: 30 Nov 2019, 21:16 Any idea what I may have done wrong?
It is a stop not a lock.
Rvolvos
Post by Rvolvos »
RickHaleParker wrote: 09 Dec 2019, 21:47
Thanks for answering, so it will not prevent the crankshaft from turning clockwise or counter clockwise?
2006 XC70 2.5T 238k
2012 S60T6 95k rip
