Should have brought snow chains.
Didn't bring snow chains.
Volvo made it third time around but the Saab needed to be emptied first. It turns out both a Saab 9-5 and a Volvo V70 will fit a lot of luggage if you stuff them to the roof but the Volvo is the bigger car inside.
- RickHaleParker
- Been thanked: 977 times
It been staring us in the face all along.bmdubya1198 wrote: 27 Dec 2019, 20:28 It's a nasty trap... it often ends in bent valves, shredded belts, leaking hoses, degrading engine mounts, and boxes in your trash can labeled "ÜRO Parts".
URO: combining form prefix: uro-
Relating to urine or the urinary organs.
Active
Past
Past
- Has thanked: 316 times
- Been thanked: 531 times
Yup! That must be exactly where they get it!RickHaleParker wrote: 28 Dec 2019, 16:33It been staring us in the face all along.bmdubya1198 wrote: 27 Dec 2019, 20:28 It's a nasty trap... it often ends in bent valves, shredded belts, leaking hoses, degrading engine mounts, and boxes in your trash can labeled "ÜRO Parts".
Tres bien!Goupil wrote: 29 Dec 2019, 04:02
New shifter cable bushes, the difference make them really worth the money !
I used MR2/Celica ones because they were cheaper, fitment is perfect
Goupil, can you give us the part numbers and source so we can document these please!
Volvo will only sell the entire shift cable at about $150 USD when I last looked into this.
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
Bought mine here, cheapest I could find with shipping to France
https://www.ebay.com/itm/Toyota-Celica- ... 2749.l2649
In the US you can get those
https://www.ebay.com/itm/VOLVO-BRASS-SH ... 0730473309
or Snabb
https://www.fcpeuro.com/products/volvo- ... escription
I know some people replace them with skate bearings as well (Robert DIY did it in one of his videos). There's also some delrin ones around
Can't seem to find a part number, I guess Volvo consider them part of the shift cable ?
or Snabb
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Well, the simple timing belt job turned into everything else that the owner wanted to do do this car! Last night, I got a 19t mounted (thanks to my cousin, who had a nice one on the shelf.... he didn't let it go easily!) and today I will take care of the NA intake manifold and throttle body, then the NA cams. This car is also getting an S90 MAF housing as well as DW200 fuel pump.
I'll make a short build thread after this just to document it. It's nice to be able to do these things to this car that I never got around to in my ownership! It will be a lot of fun once it's running!
Pop an IPD Blue spring into the CBV while you have that open. Use a new oil return oring on the block , too. Chased that puppy for 2 years
I haven’t been happy with the blue iPd spring. I left the stock one for now since it was in good shape.
As for the oil return o ring, I left it alone, but I’ll tell him to keep an eye out for leaks. It should be fine, I replaced it not too long ago.
My neighbor with his $70,000 leased Bimmer hates my IPD Blue spring, too. He has to read my tailgate every morning.I haven’t been happy with the blue iPd spring
