Volvo Cable connector
akace123
Year and Model: XC90
Post by akace123 »
Hello All
Can someone please tell me what this connector is.
I am looking for this in a Male to female as I need to extend this cable.
Photo attached
Thank you and Happy New Year Volvo People Around the World
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Where did the cable come from? What device, module ... are you extending?
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Looks like the P2 CAN network connector.
akace123
Post by akace123 »
Its a connector from the massage button cable and needs to extended to the cable where it fits into the seat, its like 3 to 4 cm short so if i can find extender cable it would be great
akace123
Post by akace123 »
SuperHerman wrote: 30 Dec 2019, 15:39 Where did the cable come from? What device, module ... are you extending?
akace123
Post by akace123 »
Rattnalle wrote: 30 Dec 2019, 15:40 Looks like the P2 CAN network connector.
I am not sure that helps as Igoogled that and not a lot help from Sir Google.
Can you advise a little more please
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Can you reroute the cable it on a shorter path?
SuperHerman
I don't think one will find an extension cable. Most likely you can find the two connector ends and then add the wires.
Best route is what RickHaleParker suggests - second best route is to pick the end of the harness with the fewest wires and easiest access and then splice in the amount of needed wire to reach. One wire at a time so no mix up, cut, strip, solder, shrink wrap and move on. Then either shrink wrap or tape the entire repaired area and add a wire loom if wanted/needed.
