I would look at fuel pressure. It sounds like you are losing pressure and hence the engine dies. This can be tested at the Schreader valve on the fuel rail in the engine bay.
When was the fuel filter last changed?
99 V70 R rough idle after warm up and stalls Topic is solved
- Has thanked: 2215 times
- Been thanked: 1853 times
- kklepack
- Year and Model: 2016 XC60
- Has thanked: 12 times
- Been thanked: 5 times
I checked the fuel pressure and when engine runs and by pressing the nipple on fuel rail fuel sprays strong, but when engine is off there is no pressure at all. Filter seems like has been replaced not too long ago. Filter looks new.
- Has thanked: 1613 times
- Been thanked: 4078 times
An ME7 car (1999 on up) needs a solid 52 psi pressure and it should hold for 20 minutes after key off.
Check the pressure with a gauge - the squirt test isnt useful on these cars. Its common for the fuel system to fail and deliver marginal pressure, causing running problems.
- kklepack
Little update: Car runs the same as before no improvement after changing below components and I still do not get any codes with VIDA.
I did compression test one more time and results are a lot better. Believe prevues gage was bad.
C1-155
C2-160
C3-160
C4-160
C5-160
New spark plugs NGK Spark Plug - NGK 6962
I did new PCV job with new blue box parts.
Replaced serpentine belt and idler.
Also replaced all vacuum lines with silicone ones and did cigar smoke test. I saw little smoke coming out of PTC nipple on the intake tube to the turbo. Also when I removed oil filler cap and dipstick smoke came out of there as well.
I did not find any other leaks anywhere else, but I hear hissing noise around by intake manifold by cylinder one where banjo bolt is and PCV (no coolant leaks)
Still have to do fuel pressure test. Went to rent fuel tester from AutoZone and it did not have right connectors.
Running out of ideas. I'm ready to take it to http://www.swedishcarspecialists.com/ and have them look at it.
C1-155
C2-160
C3-160
C4-160
C5-160
That air that is getting in there is not metered by the MAF, so the engine is not sending enough fuel to run, which will cause poor drive ability, especially at low rpm.Also replaced all vacuum lines with silicone ones and did cigar smoke test. I saw little smoke coming out of PTC nipple on the intake tube to the turbo. Also when I removed oil filler cap and dipstick smoke came out of there as well.
- kklepack
Anything else you would suggest I look at ?abscate wrote: 07 Mar 2020, 04:18That air that is getting in there is not metered by the MAF, so the engine is not sending enough fuel to run, which will cause poor drive ability, especially at low rpm.Also replaced all vacuum lines with silicone ones and did cigar smoke test. I saw little smoke coming out of PTC nipple on the intake tube to the turbo. Also when I removed oil filler cap and dipstick smoke came out of there as well.
Fix that leaks so you get no smoke
TheOtherside
- Year and Model: 1998 V70R
- Has thanked: 55 times
Same as my 98. Literally exact everything.
I just deal with it.
As for the milk on the oil cap, 100% because of moisture and short trips in the cold.
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
- kklepack
So, you are just driving it that way? Never got it fixed?TheOtherside wrote: 08 Mar 2020, 20:37 Same as my 98. Literally exact everything.
TheOtherside
It always fires back up. Rough idle never lasts long. One week itll work flawless. Next week it stalls every 5 minutes.
Any time it stalls, I hold the key, itll turn over, fire up, immediately stall, (still holding key) itll turn back over, fire up and be good for however long it wants too.
Been driving it for 11 months now.
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
- 16 Replies
- 8494 Views
Last post by valvolvo70
- 9 Replies
- 7798 Views
Last post by enriquepr21
- 1519 Views
- 723 Views
Last post by Vovo_merz
- 1272 Views
Last post by jonesboy1983
