P80 Radiator oil coolant line connection parts
- Has thanked: 311 times
- Been thanked: 817 times
In my experience the transition is clean starting in 99 yes. But I read on this forum somewhere recently that some 98 may have the squeeze locks? Or that was something else ... Just eyeballing them will settle it very simply
aahmes57
Ok, Got it. so I need two kits, $50. Thanks for straightening me out. Once I put this in then I can start it run it and test it, do the iming belt, struts etc etc. pcv
Thanks again.
Thanks again.
1991 740 (saved a life)
1998 S70 Turbo caught fire, very sad day
1995 850 sold
1999 V70 Base daily driver
1995 850 sold
- Has thanked: 316 times
- Been thanked: 531 times
Indeed you were set apart and upon.
You have to slide it onto the end of the hose, then clip it into the radiator. There's a groove in the hose end for the green clip to grab onto.Manjuu wrote: 19 Mar 2020, 12:46 Hey, does anybody know how to properly install the green retainer clips onto the oil coolant hoses and to the radiator?
You don't have oil cooler to radiator hoses on a MY 2000 unless the engine has been swapped. That uses the box style cooler on the right side of the engine, rear of car.Manjuu wrote: 20 Mar 2020, 08:32 So slide it to the end of the hose where the ring stops it? Or snap it on to the tip of the hose?
For the transmission they should look like this, and they push in until you hear the nice click of the green ears engaging the groove
- Screen Shot 2020-03-20 at 11.11.09 AM.png (533.26 KiB) Viewed 899 times
Yup, you only have a transmission cooler on your 2000, but that's how they are installed.
