electrical issues in 2014 S60 after battery change
cinematree
Year and Model: 1998 S70
Post by cinematree »
I changed the battery in my 2014 S60 T6 R-Design, replacing it with the same model from Autozone. Since changing the battery, I have two issues:
1. The clock resets to 12:00 every time I start the engine.
2. The windows don't go up and down properly. When I hit down, they go down but don't go down all the way. When I hit up, they go all the way up and turn around at the top and automatically come back down. If I hold down the switch I can do it in quick jogs and get them to stay at the top.
(everything else seems to be fine)
Any ideas on how to remedy either of these issues?
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
You might have a higher response rate if posted in the appropriate forum.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
cinematree
Ahh, I didn't see the separation of years for the S60. Thank you for letting me know. I recreated it over there, if someone could please delete it here. Thank you.
E Showell
Post by E Showell »
The window issue probably just needs an auto reset. There's a procedure on earlier model years where you pull a fuse from the fuse panel in the end of the dash when the window is being operated. It is written up on here. Try searching.
'95 855 auto (sold)
cinematree
I saw a youtube video explaining that kind of thing on a different model Volvo. I was hoping there might be some easier way of resetting it, but if not, I'll give that a try. Thank you for your response.
E Showell
Post by E Showell »
Not difficult at all. If this is the kind of thing that will send you to a mechanic, then you should sell the car now because it will eat you alive.
I am being honest, not tough.
'95 855 auto (sold)
