Hey
The temp gauge has been really intermittent so replaced The etc and termostat. But to no help.
The months passed and The temp gauge started to not work more frequently.
And now its been dead for a long time.
So got a new cluster and thought i just replace The temp gauge itself. But how do i get the needle of, is it just pulling it off. But seems stuck.
Volvo 850 temp gauge dead
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You have a '95....so you still have obdI under the hood.
Check codes for instrument cluster.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
You could just swap the whole cluster. Or move the odometer over to the new cluster with the working temp gauge.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Yes you can simply pull the needle off. I have replaced the gauge on the back of the cluster in the past to fix an issue.
The problem with swapping the cluster is that you loose the correct mileage that is stored in the cluster.
- misha
Mileage follows the cluster.
You can correct it manually on the odometer gears...but true mileage is written digitally in instrument cluster module.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
In the cluster.
True mileage will remain stored digitally in the cluster module.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
