Hy Buddies,
All is is the title.
Cheers
Manov
850 Is is possible to convert rear Drums pads to disks brakes Topic is solved
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
I was unaware that they made 850s with rear drums, or are you asking if you can make the discs operate the parking Brake?
If your car came with drums, you would need a disc brake parts car, and swap the components over. Probably at the hub. Everything from the backing plate, the hub, bearings, discs w/drum for parking brake, out to but not including, the rim. Maybe even the master cylinder, or a brake proportioning valve at the front.
Current Volvos:
- Has thanked: 1847 times
- Been thanked: 1710 times
Likewise, don't think there are rear drums on an 850 other than the parking brake drum/shoes. The rear brakes are disc/pad with the drum built into them.
- 15 Replies
- 3734 Views
Last post by jblackburn
- 546 Views
