Top Dead Center Topic is solved
TyRawr
- Year and Model: 2003 S60 2.5 Awd
- Has thanked: 14 times
How do I rotate the pistons to reach tdc for all 5 cylinders on my 03 s60 awd. Trying to perform a cylinder leak down test. Cannot find any videos for this car. Pictures, video appreciated.
Put a poo stick in each cylinder and rotate the crank,30 mm wrench, until the stick reaches max height on each cylinder, test leak down, next cylinder...repeat .
Note the tim8ng marks on crank and cam have nothing to do with indicating TDC
- RickHaleParker
- Been thanked: 977 times
Install the tester in cylinder. Turn crank with a 30mm socket clockwise. Watch the the tester. The pressure will go up when all the valves are closed. When the pressure peaks you found top dead center on the compression stroke.
Active
Past
Past
My way is superior because it takes twice as long, this putting you in better touch with your cars’ chi.RickHaleParker wrote: 13 Jun 2020, 01:14 Install the tester in cylinder. Turn crank with a 30mm socket clockwise. Watch the the tester. The pressure will go up when all the valves are closed. When the pressure peaks you found top dead center on the compression stroke.
- 3565 Views
Last post by 2521cc
- 1155 Views
Last post by oragex
- 1625 Views
Last post by Swedeneed
- 1094 Views
Last post by Filenotfound
- 2378 Views
