Chris -- have not tried reseating the ECM.
Battery holding at 13.03 V after overnight 10 amp charge and 2 + hours off the charger. Ambient temp. around 72°F.
I'll hook it up and go for broke.
'04 XC Engine Misfiring-Further Updated (Moisture ruled out - possible defective coils, bad MAF) Topic is solved
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- E Showell
I don't know what to believe. VIDA read battery voltage at one point after the charge to 13V at 10.something volts. Multimeter said 12.7. Five months short of sell by date on a 60 month battery. I'm thinking I should just replace it and take battery out of the equation since it will probably die over the winter anyway.
'95 855 auto (sold)
'95 855 auto (sold)
- Been thanked: 4068 times
I’m not sure where VIDA is reading but you might check wiring and primary circuit cables for corrosion,
Remember the battery makes it’s presence known down at the starter so , after disconnecting the negative, remove and clean those terminals until they are shiny and bright and clean
- E Showell
Well, it isn't the battery.
'95 855 auto (sold)
'95 855 auto (sold)
Grounds important too. Sean had horrible throttle body codes with a loose ground.
It’s a new day. Do you have a fuel pressure gauge? Time to forget about the past, and go full troubleshooting mode.
Ignition stuff is pretty new, so let’s measure the fuel pressure at the rail.
If you find that remote mechanic coming to do your timing belt , if s/he is at all competent, s/he will have a fuel pressure gauge
Pop open your air cleaner and see if a Jersey rats took up residence during Covid days.
- E Showell
Air cleaner is due for replacement. FCP replacement arriving today/tomorrow. Vacuumed inside of air box. Don't have a fuel pressure gauge. Could be failing fuel pump, but my prior experience with those is binary failure, i.e., it either works or doesn't all of a sudden.
'95 855 auto (sold)
'95 855 auto (sold)
Not on a P2. Whethe PEM acts up, I had six months of occasional stumble, then finally a no start.
Fuel pressure tells tale.
- E Showell
I have a spare PEM somewhere. Just have to locate it, and location on vehicle. Never even considered failing PEM. Thanks for that suggestion.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
Would a bad fuel pressure sensor give me a CEL and/or DTC?
'95 855 auto (sold)
'95 855 auto (sold)
- 3133 Views
Last post by itsmekirby
- 5976 Views
Last post by chrism
- 2239 Views
Last post by MoVolvos
- 357 Views
Last post by JaredR
- 26 Replies
- 6468 Views
Last post by ChadLee
