VIDA scanner
patcal
Year and Model: 1998 S70 GLT
Has thanked: 99 times
Been thanked: 10 times
VIDA scanner
Post by patcal »
Hi all,
    With a VIDA scanner will I be able to reset my service light, program remotes?  Does anyone have a link for info on just what I could do with this?  Here is a eBay link.  Would this be the right one?
https://www.ebay.com/itm/VIDA-DICE-2014 ... 4902.l9144
Thanks
Pat Callaghan Jr.
98 S70 GLT
patcal
Post by patcal »
I am also looking at a icarsoft vol2. Recommendations?
Pat Callaghan Jr.
98 S70 GLT
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
I don't know anything about VIDA, but the service light (the one that literally says "Service") can be reset in my s70 with a trick of holding down the trip odometer reset button and turning the key to position 2 until it starts flashing and then turning the key back and removing it. Or something like that, there is a video and another website has a write up on it in text.
07 V50 T5 AWD M66 ~146k miles
patcal
Post by patcal »
smacknab wrote: 20 Jul 2020, 12:00 I don't know anything about VIDA, but the service light (the one that literally says "Service") can be reset in my s70 with a trick of holding down the trip odometer reset button and turning the key to position 2 until it starts flashing and then turning the key back and removing it. Or something like that, there is a video and another website has a write up on it in text.
Doesn't work on mine. Seems there is a point where they changed. What year is your S70?
Pat Callaghan Jr.
98 S70 GLT
smacknab
Post by smacknab »
patcal wrote: 20 Jul 2020, 12:30
Ah weird, mine is a 99
Has thanked: 1847 times
Been thanked: 1710 times
You need a reset tool for a 98 for the Service light. There used to be cheap tools out there that could do that and the Airbag light on the 98's but I am not sure if the icarsoft will work on a 98. Vida only works on 99- P80 car electronics and software.
The Vol-Fcr and a VW connector cable to your laptop is the way to go. If you post a request for help on that or look at the Forum specific for that there is a lot of info in there.
Neil
Has thanked: 292 times
Been thanked: 765 times
For a 98, to program remotes you must go to the dealer or a shop that has the dealer software.
The best way to reset the service light is to remove the bulb. Foolproof, permanent and trouble-free.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
esl_97_850_T5
Has thanked: 18 times
Been thanked: 27 times
Post by esl_97_850_T5 »
If you have an Android device, you can use
xiaotec "850 OBD-II" Android app (available on Google Play) for ~$2 + ELM327-compatible Bluetooth tool.
Some ELM327-compatible Bluetooth tools I've used successfully with "850 OBD-II" app:
- ScanTool.net OBDLink LX BT [recommended]
- ScanTool.net OBDLink MX+ [the most useful long term, though the costliest] [most highly recommended] [this is MX+, not MX BT or MX WiFi]
- BAFX Bluetooth [adequate, cheapest of the 3]
Here's a related post with a little more detail:
viewtopic.php?f=1&t=34190&start=70#p548535
esl_97_850_T5
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
esl_97_850_T5 wrote: 22 Jul 2020, 18:43 If you have an Android device, you can use
If you do not have a Android device you can use a Android emulator.
I have used the free Noxplayer with 850 OBD-II it works good. There are both PC and Mac versions of NoxPlayer.
There are a bunch of Android emulators for Linux. I have not tried any of them.
There is good chance any Android emulator will work with 850 OBD-II.
patcal
Post by patcal »
I already use Torque Pro with a OBDII bluetooth. Works great for basic system codes, live data. I was just thinking of a more advance scanner. Going to wait for now. Thanks for all the input.
Pat Callaghan Jr.
98 S70 GLT
