Hi,
I cant find the codes or reset the check engine light. I've tried holding the read button and pressing the light (fog?) button. No messages, I've used my obdII reader, it showed no codes (DTC) nor would it reset the light.
It runs like it should, the only issue I have is that I have to refuel very slowly otherwise it gushes fuel back out (another issue I need answered)
What should I try next?
Thanks
2002 s60 check engine light
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
The trick is to hold the "read" button while simultaneously pressing (twice) the rear fog light button.Dux wrote: 04 Aug 2020, 13:46 Hi,
Thanks
There's a valve that prevents fuel from gushing out in the event of a roll-over. I'd be suspicious of this first and foremost.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 45 times
Holding the "READ: button and pushing the rear fog lamp button will only access the message panel and let you know if DTC's were set on specific modules. It will not tell you the specific DTC code.
If your OBDII reader can't reset the check engine light or read any DTC's, you need a better reader or VIDA/DICE.
Lots of posts in the forum about VIDA/DICE.
Good luck.
Good luck.
93SCMax
Glad you were able to pull the codes.
Both are emissions codes. I'd recommend you tighten or replace your gas cap, reset the codes and then see if they come back.
If you overfilled your tank recently, that also could throw an emissions code.
Good luck.
Good luck.
- 788 Views
Last post by rubbersidedown
- 2321 Views
Last post by oragex
- 9 Replies
- 6656 Views
- 2875 Views
Last post by Georgeandkira
- 1518 Views
Last post by cbburtraw
