Rig that wire up, take the safety precautions noted above , and try that bypass.
Text me to walk through on a FaceTime
- Has thanked: 1611 times
- Been thanked: 4075 times
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Already feeling 100lbs lighter... removed the secondary air pump yesterday while the wife was on a call. Delete was done at the ECU a few days ago.
Sigh... I really hope this is the magic fix. I don't know how I'll bring myself to junk this if this doesn't get my monitors ready for inspection.
Retired:
2015 Volvo S60, T5, 85K
- amblerman
- Year and Model: 1999 s70
- Has thanked: 2 times
- Been thanked: 70 times
Ok great. Thanks.
The reason I asked is I have always been able to find Zerex G05 in both 50/50 and concentrate at Napa.
I searched napaonline.com and they also show both the 50/50 and concentrate G48 in stock and in store local to me.
If you have a Napa near you that might be a source for you. I have also found my local napa helpful when ordering things they don't typically stock. I know some people have bad experiences with napa but I like mine.
What drives me nuts about Zerex's current labeling is their 50/50 bottles clearly state they are 50/50 mix right on the front.
The concentrate? nothing...I believe their concentrate jug does mention mixing on the back but nothing on the front that mentions it being a concentrate.
So watch out for that.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Got one side of the front of the R brakes installed on my '97 T5 today.
brunocerous
- Year and Model: 1998 V70
- Has thanked: 303 times
- Been thanked: 43 times
Woo hoo! Fingers crossed!theWIFES_S70 wrote: 05 Aug 2020, 13:22 Already feeling 100lbs lighter... removed the secondary air pump yesterday while the wife was on a call. Delete was done at the ECU a few days ago.![]()
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Very clean brakes - I like the green ! Are drilled/slotted rotors a no no on these cars ? Just wondering...
And I think everyone has their fingers crossed. No one wants to see this turn out badly. Praying to the Volvo gods
1999 V70 GLT
1999 V70 GLT
My tip for the day
Intake manifold (IM) installation
4 M7 bolts into slotted holes on IM
4 M7 bolts up top into full holes On IM
One M8 bolt up from below through metal angle bracket shown below
My advice? Attach angle bracket to IM loosely with M8, after getting IM M7 bolts torqued, go back , insert lower M8 and M6 wiringharness bolts, tighten them to torque
Much easier than threading in M8 blind, upside down
- smacknab
Today my cars ac wasn't kicking on. I shut the engine, pulled the ac fuse (fine), pulled the relay and shook it (no rattle), and pulled the little electric wire that runs to the compressor and reconnected. Restarted the car and the ac kicked on but was cycling at idle, on the highway it stayed on without cycling. Temp was 91 plus humidity today.
I'll monitor it but cycling compressor in most cases means low freon, right?
07 V50 T5 AWD M66 ~146k miles
Not with a COTS like our P80s
It has to be really cooking for 100% compressor duty cycle
