03 S60 T5 Heater problem
Umirinbrah
- Year and Model: 2003 s60 T5
Of course it’s the first cold morning of the year and I go to test my heater and it is super weak. The fan is very weak when set to heat but blows just fine on ac. It also takes a long time to heat up. Any idea what this may be?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Did you recently bought the car ? Did it work properly last winter ?
What do you mean by the fan being weak ? Not much air coming off the vents? Does it blow more air when the AC is on ?
Umirinbrah
Yes i just got the car about 10 days ago and i wasn't able to test the heat because it was about 30c when i bought it lol. By weak fan i mean the air doesn't come out of the vents very hard when i set it to heat but when using the ac the air comes out considerably harder.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 78 times
I'm not sure you can make a comparison between air output with heat vs air output with AC. The system probably wants to push air down to the footwell vent when the heat is on and more air out of the dash vents when the AC is on, especially when you have the "Auto" air control button selected. What happens when you push the other two buttons? They should direct more air out of either upper or lower vents per the arrows on the buttons.
- oragex
As above, if the Auto button has a green light, press one of the three 'human' buttons to engage the manual mode - press the center one for example. Otherwise it may have a faulty thermistor - but not sure
- Has thanked: 1511 times
- Been thanked: 3827 times
The blower won’t come on until the car has made some heat in the motor, it’s very kind when it’s -40C
If you put in manual mode by turning up the fan speed switch it should blow just like the AC
- 32 Replies
- 16109 Views
Last post by sleddriver
- 23 Replies
- 5754 Views
Last post by callahanoffroad
