03 S60 T5 Heater problem
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Umirinbrah
Year and Model: 2003 s60 T5
Post by Umirinbrah »
Of course it’s the first cold morning of the year and I go to test my heater and it is super weak. The fan is very weak when set to heat but blows just fine on ac. It also takes a long time to heat up. Any idea what this may be?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Did you recently bought the car ? Did it work properly last winter ?
What do you mean by the fan being weak ? Not much air coming off the vents? Does it blow more air when the AC is on ?
Umirinbrah
oragex wrote: 26 Aug 2020, 13:39 Did you recently bought the car ? Did it work properly last winter ?
Yes i just got the car about 10 days ago and i wasn't able to test the heat because it was about 30c when i bought it lol. By weak fan i mean the air doesn't come out of the vents very hard when i set it to heat but when using the ac the air comes out considerably harder.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
I'm not sure you can make a comparison between air output with heat vs air output with AC. The system probably wants to push air down to the footwell vent when the heat is on and more air out of the dash vents when the AC is on, especially when you have the "Auto" air control button selected. What happens when you push the other two buttons? They should direct more air out of either upper or lower vents per the arrows on the buttons.
oragex
Post by oragex »
As above, if the Auto button has a green light, press one of the three 'human' buttons to engage the manual mode - press the center one for example. Otherwise it may have a faulty thermistor - but not sure
Has thanked: 1511 times
Been thanked: 3827 times
The blower won’t come on until the car has made some heat in the motor, it’s very kind when it’s -40C
If you put in manual mode by turning up the fan speed switch it should blow just like the AC
