Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
I got mildly disappointed today, as for the first time in 3 years my 850 let me down... Crank but no start scenario, troubleshooting begins tomorrow (bank holiday, luckily!). Currently I suspect CPM as I have both fuel and air, and my crank speed is normal so starter is good. Haven't checked spark yet, but its the only one left. If I have air, fuel, and spark I will terribly confused. Oddly, it does cough every 20s or so of cranking, and tries to run for 0.5-1s. I suppose lawnmower syndrome is plausible, but I have no recollection of starting the car since Fri when it completed an 80mi trip.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
I think you're on the right track. Check either the cam sensor or crank sensor.
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
New wheels and finally managed to get the trailer hitch off the parts car!
Picture of wheels
POS trailer hitch
2008 S60 2.5T Auto (Sold)
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Rolled my fenders some more because I was getting alot of rub last night with 3 passengers in the car. It seemed like it was mostly hitting the plastic so also pulled the wheel well liners and cut out some clearance there too. While I was in there I took a wire wheel to the surface rust and hit them with a couple coats of rust-reformer paint.
Also replaced my super crusty exhaust manifold with an aftermarket unit from 1A Auto, plus Volvo gasket and hardware. I ran out of time so I only replaced 4 of the exhaust studs.
Odometer hit 219k today
07 V50 T5 AWD M66 ~146k miles
Has thanked: 1611 times
Been thanked: 4075 times
It’s a tiger, ready to pounce, its5 gears anxiously awaiting its owners’ command....
smacknab
Post by smacknab »
abscate wrote: 31 Aug 2020, 05:07 It’s a tiger, ready to pounce, its5 gears anxiously awaiting its owners’ command....
Haha oh yeah this thing is a real animal
Instead of lunch I put Earls heat back in
New heAter core bulkhead , flush and test
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Fun times. That junction is such a pain for me to get to.
Its a real b***** isn’t it?
Job tips to be documented
Pull the gas pedal out of the way, pull pin to left. Unclip pedal
Yellow clamps face down to engage slots
It’s just possible to sneak the bi]ulkhead past the climate unit without removing it.
Top goes spacer oring spacer oring
Torx 25 on heater core screws, Torx 15 on side screws
Torx 25 machine bolt on core bulkhead, dimension in picture
Two orings on water pipe connect
smacknab
Post by smacknab »
Swapped my brake pedal position sensor since I had a p1041 and a code stored in the ECM for it, plus no cruise control. Before I did it I read that for 99's sometimes the ETS light is tripped by the position sensor. Now my 1041 is gone, cruise control is back and what do you know 100 miles of mixed driving later no ETS light either.
