CVVT worn out?
850T5Ritalia
Year and Model: 1995 T-5R
Has thanked: 5 times
CVVT worn out?
Post by 850T5Ritalia »
Hej, when taking the head off a V70 I found the CVVT hub having some play. I made a little video to better show what I mean. It looks to be maybe 1.5- 2mm of axial play. I didn't found any oil leaks. I've seen a lot of people talking about these CVVT things going bad and I was wondering is this one is still usable.
- Pete -
Has thanked: 80 times
Been thanked: 175 times
Post by - Pete - »
Look at the inside face of the sprocket for oil/residue (opposite side of the yellow hub). As in, the opposite side of where the cogs are, inside the wheel. You may need a small mirror or inspection camera. If there is no evidence of oil leaking I would leave it alone. Jimmy57’s CVVT cutaway thread talks about the max allowable amount of axial play.
I replaced both VVT hubs on one of our P2’s at about 280k miles. Axial play, if I recall correctly, was around .67mm and both had begun to leak. Mine looked much like the play you show in your video.
There is an o-ring inside the VVT (opposite the T-55 plug) that is replaceable, used to be tricky to source. I sourced some well before FCP carried them, but they were incorrectly sized so I ultimately ended up replacing both VVT’s.
https://www.fcpeuro.com/products/volvo- ... s-9497786s
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
850T5Ritalia
- Pete - wrote: 04 Sep 2020, 19:05 Look at the inside face of the sprocket for oil/residue (opposite side of the yellow hub). As in, the opposite side of where the cogs are, inside the wheel. You may need a small mirror or inspection camera. If there is no evidence of oil leaking I would leave it alone. Jimmy57’s CVVT cutaway thread talks about the max allowable amount of axial play.
Thank you. Ill try to find that O-ring here in Europe first and see if it last for a little longer. Also with the non-spring loaded hubs like mine, if I just put it back lining up the marks from the pully with the cam cover wil it be good to go?
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
850T5Ritalia wrote: 05 Sep 2020, 03:57 Also with the non-spring loaded hubs like mine, if I just put it back lining up the marks from the pully with the cam cover wil it be good to
If you did not mess with the bolt that holds the CVVT to the camshaft the answer is yes, you can treat them as if they where not CVVT. If you loosen that bolt the answer is no, you have some CVVT to Camshaft alignment to do.
850T5Ritalia
RickHaleParker wrote: 05 Sep 2020, 04:14
I did take the CVVT hub loose from the camshaft. I also marked the spot where it was sitting in its most clockwise position when the cams where locked together. My understandig from a couple vids that I watched is that the most clockwise position should be where it lines up with marks on the cam cover. thanks
RickHaleParker
850T5Ritalia wrote: 05 Sep 2020, 04:27 I watched is that the most clockwise position should be where it lines up with marks on the cam cover. thanks
You are mission steps and it does need to be done with precision. Read the attached PDF.
2003_V70_Timing.pdf
(235.95 KiB) Downloaded 210 times
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
that play isnt an urgent repair. Mine had similar play in it, i replaced the VVT with a used one after a while and noticed that it fixed the belt moving side to side (walking) and the tensioner needle jumping/pulsing. so its smoother..
2001 XC70 factory M58
2002 XC70 auto (parts car)
850T5Ritalia
RickHaleParker wrote: 05 Sep 2020, 05:09
Thank you for the instructions. So just to be clear, this video is also missing the steps of taking the gear loose from the hub? Is that really necessary? I marked all those positions and its a non spring loaded hub on my car. So when I line up the marks before putting the belt on its not likely to move.
RickHaleParker
850T5Ritalia wrote: 06 Sep 2020, 04:15 Thank you for the instructions. So just to be clear, this video is also missing the steps of taking the gear loose from the hub? Is that really necessary?
From what I recall. You can get the Cam cover off without removing a Non-VVT gear from the camshaft but a VTT will catch on the head.
