The infiniti, I can take out and fully disassemble the volvo headlight in the time it takes to pull off the bumper. 3 bolts and your doneCIK7 wrote: 08 Sep 2020, 22:56Are you refering the lightbulb/headlight swap to the infiniti or volvo? I asume infiniti becausethe 70 series p80 doesnt require that work. p80 70s are easy. Unless as you sat the headlight bolt strips. Those are 6, not 8 though.yanga001 wrote: 08 Sep 2020, 19:25 To lighten the mood, sometimes one needs to carry tools to fix their own tools. I carry an ifixit pro kit for the days when my air pump switch decides it wants to bind up. need to fix the air pump to fix the volvo![]()
Added to the list: Zip ties (for any random fixes, or to release tension on electrical cables)
-Needed to use them to fix a friends infiniti. Those cars make me appreciate how easy it is to take a headlight out of any volvo. It was 7 push pins, 8 10mm bolts. 3 hours spent trying to remove two bolts since there shitty plastic decides to snap and allow the bolts to spin in place. All of that to replace a ballast in a headlight. Hell you have to pull back the wheel well cover and blindly stick your hand in just to replace a lightbulb (rant over).
breaker bar, for extra stubborn bolts.
Battery terminal cleaner (those wire brushes work wonders)
floodlight with a small inverter
edit: changed headlight to lightbulb
Presenting Everyday Carry video (YT) of my mint Volvo
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
2008 S60 2.5T Auto (Sold)
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Carrying a breaker bar has been mentioned, but length makes all the difference here. They are not that easy to find, but each of my cars has a 30" bar. That will get the most stubborn lug bolts either loose, or snap them off
I always advocate non violent conflict resolve, but I suppose they could be re-purposed
Other items you will find in my cars are wheel chucks, a set of warning triangles and of course a portable 12 volt air compressor.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
I love the simplicity and ease of fixing/replacig a lot of the volvo parts. The one replacement im dreading is the 960 heater core because the people that have done it say that the car must have been built around it. In other words, its a pain.yanga001 wrote: 09 Sep 2020, 07:02The infiniti, I can take out and fully disassemble the volvo headlight in the time it takes to pull off the bumper. 3 bolts and your doneCIK7 wrote: 08 Sep 2020, 22:56Are you refering the lightbulb/headlight swap to the infiniti or volvo? I asume infiniti becausethe 70 series p80 doesnt require that work. p80 70s are easy. Unless as you sat the headlight bolt strips. Those are 6, not 8 though.yanga001 wrote: 08 Sep 2020, 19:25 To lighten the mood, sometimes one needs to carry tools to fix their own tools. I carry an ifixit pro kit for the days when my air pump switch decides it wants to bind up. need to fix the air pump to fix the volvo![]()
edit: changed headlight to lightbulb![]()
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- CIK7
CIK7 wrote: 09 Sep 2020, 08:28I love the simplicity and ease of fixing/replacig a lot of the volvo parts. The one replacement im dreading is the 960 heater core because the people that have done it say that the car must have been built around it. In other words, its a pain. On the other hand, the HC replacement on my 98 XC was a breeze.yanga001 wrote: 09 Sep 2020, 07:02The infiniti, I can take out and fully disassemble the volvo headlight in the time it takes to pull off the bumper. 3 bolts and your doneCIK7 wrote: 08 Sep 2020, 22:56
Are you refering the lightbulb/headlight swap to the infiniti or volvo? I asume infiniti becausethe 70 series p80 doesnt require that work. p80 70s are easy. Unless as you sat the headlight bolt strips. Those are 6, not 8 though.![]()
- CIK7
This is the new edc video. It is 9 min instead of previous 20 min.
- 1173 Views
Last post by CIK7
- 1172 Views
Last post by matthew1
- 17 Replies
- 2146 Views
Last post by CIK7
- 15 Replies
- 2786 Views
Last post by JimBee
- 1898 Views
Last post by theWIFES_S70
