2004 s60 a/c blower intermittently not working
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
There could be a short in a wire/corroded connector or module under the dash - such as from water/coolant leak. The blower should not have voltage without keys in ignition.
mario555
- Year and Model: S60 D5 Optima, 2003
Hello everybody,DGM wrote:Verify/replace fuse (11C26) on the left hand side of your dashboard (30 Amps). It could be deformed or damaged. Check wiring and plug terminals. Measure battery voltage at the control unit (4/31) plug. Verify ground continuity from the plug to the chassis. The control unit regulates motor speed (6/28) based on the signal received by the CCM (3/112).
If you find nothing have the car scanned for codes ideally with Vida-Dice. You may have a condition that interfere with the CCM operation.
My S60 has similar failure. Following check by Vida I was told the fan control module (ref. component 4/31 in the diagram) is damage. Can you tell me whether it is embedded in the motor or nearby it? Thank you
Mario
- Been thanked: 4068 times
If you use the AC late P80s (P2s?) will run the blower after the car is shutoff to dry the evap core.
I believe my newly acquired P2 has this in the owners manual, too.
- 696 Views
Last post by Mojobaby27
- 718 Views
- 1135 Views
Last post by RickHaleParker
- 3030 Views
Last post by jlh3rd
- 1101 Views
Last post by volvomadness
