Hy Buddies ,
There is nothing more annoying to me that ones who look for answer, pick up some here, and never give the result. So, for my clutch : it's in progress. The car is up and the gearbox is out : it seems that the fork wasn't the right one, and apparently, there is a clip and a spring are missing. The good new is that the way I've bleeded the clutch stuff was a good one (thanks to Chuck and Volvolugnut for advices).
I will call my Volvo dealer tomorrow to order the parts.
A fork, a spring, a pin and a clip : do I forget something ?
Manov
850 Hydraulic clutch issue, the return
- Has thanked: 2215 times
- Been thanked: 1853 times
I did suggest here may be a problem with the fork!! But I would not have thought the wrong one was fitted or parts missing. It was the only way I could see the slave cylinder rod over extending. Hopefully, this is now the issue getting fixed for the last time.
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 675 times
- Been thanked: 164 times
Yep ! Does someone can guide me to list the parts I need ?scot850 wrote: 03 Dec 2020, 10:44 I did suggest here may be a problem with the fork!! But I would not have thought the wrong one was fitted or parts missing. It was the only way I could see the slave cylinder rod over extending. Hopefully, this is now the issue getting fixed for the last time.
I'm sure you did before, but can you send me your Vin# and I will pull out the Vida laptop tonight and see if I can find the part numbers you need.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
So, someone has been messing around in there before you, if the fork is incorrect.
The missing bushing would've caused the over-extension of the slave cylinder, but it sounds like someone put it back together wrong in the first place.
- 28 Replies
- 9396 Views
- 102 Replies
- 12433 Views
- 1319 Views
Last post by RickHaleParker
- 35 Replies
- 17377 Views
- 886 Views
Last post by erikv11
