2003 V70mbase Recognize this sound? 31400693 Topic is solved
Biggertuna
Year and Model: 2014 S60 T5
Has thanked: 12 times
Post by Biggertuna »
My '03 V70 Base (~180K mikes) is making an odd noise after I turn it off. The noise starts off quite loud, decreases a bit, then continues for 2-3 minutes until it's gone. I've never heard it before and it appears to be coming from underneath the air filter. See link to video below.
Any guesses or ideas of the cause? Thanks for the help!
Video
https://www.dropbox.com/s/wjy7a2jgkcwxu76/V70Noise.mp4
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Sounds like a tired vacuum pump. You may have a vacuum leak somewhere, one place to start is the 'switch' right in the center of the video with brown connector. On the switch, it says 'motor' on one side, make sure it's the hose that goes down towards the pump. If that's fine, may try replacing the switch if the cap looks broken - but no guarantee it will quiet the pump. My pump was buzzing because the brake pedal seal to the brake booster was leaking - may search on youtube
Biggertuna
Checked the 'switch' and upon touch, the cap sprung off so I'll have to replace it. Otherwise, the hoses look ok and are connected in the proper order.
Thanks for the tip. Let's see what happens after I replace the switch.
Been thanked: 4065 times
That’s it. If you put a zip tie around the switch before it springs apart you save yourself switchreplacemrnt.
The new one is improved design, I believe, but a zip tie on a junkyard one or used replacement
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Although a switch, I have referred to this as the "jack-in-the-box valve" in the past. Now you know why.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Biggertuna
Swapped out the old switch today with a Volvo replacement (couldn't find OE/OEM/Aftermarket). Noise is gone and brakes aren't as spongey either.
Replacement switch appears to be of better quality as well. Don't think I'll be experiencing the "jack-in-the-box" effect again.
Thanks for the help.
Added model and part number to thread title
The new part is improved design from OEM
https://www.fcpeuro.com/products/volvo- ... o-31400693
Biggertuna
I ordered this one. I think it's the same part, but different OE numbers.
https://www.fcpeuro.com/products/volvo- ... o-31265825
