This really looks like the way to go to me...trying to figure out if the cups on this are 8mm or not, and if the spring retainer clips come with it. Even if this is too long or short, its close enough to be able to shorten the threaded sections or add longer ones as needed.
https://www.partsklassik.com/p-2494-dro ... 0-tin.aspx
I'd happily pay $22 to have this part made of all metal
P80 (-1998) Throttle Body Rod 3507883 Dicussion
- SonicAdventure
- Year and Model: 1996 850 wagon
- Has thanked: 59 times
- Been thanked: 12 times
- Been thanked: 4069 times
This thread is everything That makes MVS great; a problem, multiple solutions, users helping each other out (Thanks Sonic), international intrigue, someone used ‘plethora’ correctly, Oxford commas, and semicolons.
I left off someone started a thread using a part number.
Update. FCP showing this part is available ? I’ll email to check
Positive review in June 2020?
https://www.fcpeuro.com/products/volvo- ... 70-3507883
- NitroVolvo
- Year and Model: 1998 S70 T5 SE
I just ordered this part, hope it fitsSonicAdventure wrote: 05 Sep 2020, 10:53 This really looks like the way to go to me...trying to figure out if the cups on this are 8mm or not, and if the spring retainer clips come with it. Even if this is too long or short, its close enough to be able to shorten the threaded sections or add longer ones as needed.
'98 S70 T5M SE (The Silver Surfer)
'98 S70 (Vladimir the Volvo)
Retired: '98 S70 T5 SE (Black Jacques Shellac)
Retired: '91 740 TM (Silver Fox)
Retired: '89 740 (Grey Ghost)
did this work for you guys https://www.partsklassik.com/p-2494-dro ... 0-tin.aspx
and i found this has anyone used this before https://www.snabb.us/Throttle-linkage-A ... p_135.html
- NitroVolvo
Update,
No, it didn't work. It was too short. I have a good friend who's a wiz in the garage and he cut one end and welded a old screw onto it to give me the length required. I think this one would work better, bit there's no details on the actual length!
https://www.partsklassik.com/p-2587-mfi ... steel.aspx
+1000 points for ‘ Vladimir the Volvo’
Spasibo!
Spasibo!
- 10 Replies
- 608 Views
- 2727 Views
Last post by manovlov
- 2609 Views
Last post by shaker_chi
- 1677 Views
Last post by charleskennedy23
- 1368 Views
