My 850 hates me
Cailin
- Year and Model: 1996 850
So I thought my flashing transmission arrow issue was fixed by replacing a small leaky hose. Now it's back to solid transmission arrow, that will often go off if I turn it off and sit for a few minutes. I still think it's an air flow issue. And I discovered this little hose (see pic) that doesn't connect to anything on one end. Any ideas where this should be? Could it cause my issues? Also my cracked hose (pictured) might be a contributing factor? As always, I apologize if these are dumb questions, I am obviously not a mechanic.
- Has thanked: 1613 times
- Been thanked: 4078 times
That’s either SAS solenoid vacuum or air door vacuum for the air cleaner. I don’t think either one will cause a transmission fault
The broken ECU housing vent, the fat elephant hose, won’t either
Cailin
Thanks abscate! After a quick google search I think it’s the SAS solenoid vaccum. (There’s a connection for it that I remember that is now missing). I think part of my issues are that the mount of the panel above the radiator broke and it caused some things to shake loose. (Pic is after I put it back into place with zip ties).
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
You're probably going to need to scan that sucker and see what the car thinks is wrong... It should have a hard code set, so at least you aren't tracking down an intermittent problem.
2023 Lexus RZ450e -66k
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- rspi
Contact rspi..
Not checking the system's OBD2 system is like seeing your girl friend stomp around the house, tossing your belongs in the trash and not asking her what's wrong. It's a simple question, when you ask, the reader will tell you. BTW, I do hate when people don't ask what's wrong. lol
- 873 Views
Last post by erikv11
- 4746 Views
Last post by tryingbe
- 713 Views
Last post by shaker_chi
- 940 Views
Last post by misha
- 1963 Views
Last post by misha
