Thanks, i'll try that!
Tips on removing the head on a -99 v70 2.5t
- Has thanked: 1611 times
- Been thanked: 4072 times
Here’s a good 10 minute video with no chaff on hub removal
One addition
Before you remove the timing belt, use a 30mm impact to loosen and lube the crank pulley nut. You need to remove the harmonic balancer and pulley to get the timing belt on with The later RN blocks, 1999- on
You will find people who say it can be done with the pulley in place, which is true, but trust me on this, remove them
You might need 30mseconds of propane heat on the crank pulley nut to help it zip off.
One addition
Eliotlm
- Year and Model: 1999 Volvo v70 2.5t
What video are you reffering too? Did you Link it? I have a pneumatic impact Gun but it is quite weak so im unsure if i am able to get it off, but ill try. But the reason for taking it off is to put the new timing belt on easier?abscate wrote: 14 Jan 2021, 07:13 Here’s a good 10 minute video with no chaff on hub removal
One addition
Eliotlm wrote: 14 Jan 2021, 14:39What video are you reffering too? Did you Link it? I have a pneumatic impact Gun but it is quite weak so im unsure if i am able to get it off, but ill try. But the reason for taking it off is to put the new timing belt on easier?abscate wrote: 14 Jan 2021, 07:13 Here’s a good 10 minute video with no chaff on hub removal
One addition
Sorry. Here is the link
Eliotlm
Thank you! I just ordered some ratcheting wrenches to get off the exhaust manifold, which is a real paint, i'll get on with the timing after that!abscate wrote: 14 Jan 2021, 18:14Eliotlm wrote: 14 Jan 2021, 14:39What video are you reffering too? Did you Link it? I have a pneumatic impact Gun but it is quite weak so im unsure if i am able to get it off, but ill try. But the reason for taking it off is to put the new timing belt on easier?abscate wrote: 14 Jan 2021, 07:13 Here’s a good 10 minute video with no chaff on hub removal
One addition
- 4469 Views
Last post by ggleavitt
- 2506 Views
Last post by Roger_850T
- 56 Replies
- 12937 Views
Last post by smacknab
- 1170 Views
- 15 Replies
- 4023 Views
Last post by E Showell
