Vida 2014D Times out 12/31/2017 23:59 Topic is solved
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
MikeyS60 wrote: 21 Jan 2021, 07:31 don't think i can find a junk one and replace on this car
Clean and reset the electrical connector first.
Active
Past
MikeyS60
Year and Model: 2005 S60
Post by MikeyS60 »
i will go remove it now to clean thank you. reset??
RickHaleParker
MikeyS60 wrote: 22 Jan 2021, 07:24 reset??
Yes clear the codes.
The only way you will know if it fixed the problem is to clear the codes and see if they come back.
Active
Past
MikeyS60
Post by MikeyS60 »
oh ok. thought you ment something else by reset. i am in the process of tracking down an E5 torx so i can remove it
60cents
Year and Model: 2005 xc70,2004 S60R,
Post by 60cents »
I'm trying to find the VIDA 2014D-RePack file.
Does anyone know where to look?
The link in RickHaleParkers post above doesn't work.
It takes me to google translate and then google won't connect to the store.
RickHaleParker
60cents wrote: 13 Apr 2021, 14:48 I'm trying to find the VIDA 2014D-RePack file.
Use the Alternative instructions and Magnet link on page 16. The hyperlinks are all dead now.
Active
Past
60cents
Post by 60cents »
Thanks Rick but where is page 16
60cents
Post by 60cents »
Never mind Rick.
I figured it out, duh...
dedubyah
Year and Model: 2006 XC90
Post by dedubyah »
RickHaleParker wrote: 27 Jan 2019, 06:24 DiNCA Something minor did not go right on your install. There is an easy fix, Locate C:\VIDA\WslLogin.exe.
and rename it to WslLogin.exe.bak Reboot then login as admin.
Hi Richard,
I have the same message however when I go to C:\VIDA I dont see C:\VIDA\WslLogin.exe. listed only WslLogin.exe.bak
which is a 65kb BAK file. Not sure what to do, any advice? thx
Dale
RickHaleParker
dedubyah wrote: 27 Apr 2021, 19:00 I have the same message however when I go to C:\VIDA I dont see C:\VIDA\WslLogin.exe. listed only WslLogin.exe.bak
What have you done and tried?
Did you try login in as admin after renaming the file and rebooting?
Active
Past
