Part # for left lower oil cooler hose?
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
The one that is leaking is the drivers side exit line that attaches to the radiator right above the rad hose. Its short and looks accessible. I'm hoping to pluck it off there without too much angst. Think I can do that without draining anything beforehand? Thanks. 96 850t.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Driver side should be the transmission cooler hoses. The outlet hose should be part# Volvo 3507931
Inlet hose 31274778
https://www.fcpeuro.com/products/volvo- ... 70-3507931
https://www.fcpeuro.com/products/volvo- ... 50-9142789
I want to say the lower hose is the inlet?
Inlet hose 31274778
rguzz
The one I need to replace looks like this one, transmission yes thanks. https://www.fcpeuro.com/products/volvo- ... 70-3507931
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
You can do it without draining the ATF, pretty sure it causes a bit of a mess either way. That being said, if you have done an ATF refresh in a while, it wouldn't hurt to combo it. A drain and fill will take about 3.5 quarts.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Been thanked: 4068 times
Upper one pushes oil into the radiator
Lower one flows from radiator to transmission
rguzz
I'll do it, I think it's the only remaining (really) leak on this car. It was tricky because it drips and blows back, the hose itself just damp where it meets the lower fitting. But I finally caught it dripping on the lower radiator hose so there it is, and it's the original. Looks like the line comes with O rings and necessary bits to complete the install. I will add a small clamp to the fitting on the radiator side. Within last year I did drain and fill x3-4 was always surprised at how dark the fluid can get so quickly. Thanks!
- 2140 Views
Last post by fitz548
- 18 Replies
- 6426 Views
Last post by Mark1967
- 1601 Views
Last post by SuperHerman
- 1126 Views
Last post by MDK
- 1071 Views
Last post by erikv11
