The Resurrection of (10/1998 to 01/2021, 11/21- 11/25) Elizabeth 1999 V70T5M56 Cylinder Head Job Topic is solved
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
BlackBart wrote: 04 Feb 2021, 14:42 But he's out in the street in a snowstorm....with some gloves.
1. Power Inverter to power the heating pad or a long extension cord.
2. They do make rechargeable battery powered heated gloves. You can pick up the gloves for ~$15.00 - $20.00.
Active
Past
Has thanked: 1613 times
Been thanked: 4078 times
Used the Mopar upper cylinder head product to clean the piston tops. This stuff is magical
Apply, soak overnight, wipe with paper towel....
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
wait....you have some sort of mud volcano going in 4 and 5.
Also - isn't all the grime and grit getting down the sides to the ring lands and scraping up the walls? Any way to suck that out of there with a tiny vac nozzle?
It got cold enough for the solvent to freeze
It will get washed down with solvent into the sump, then air blasted to get rid of particles
It’s an engine, not a Neuron.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
abscate wrote: 05 Feb 2021, 14:22
True. Engines always ingest some dirt. It gets collected in the filter. Similar to the crud in our bodies, it gets collected in the waste streams and filtered in the kidneys.
In both cases, if you clean most of it up, the patient will live a while longer. Ever had a barium lower GI exam? Nasty stuff, but it flushes out in a few days.
BlackBart
Post by BlackBart »
Oh. I just assumed some of that grit would be dragged by the rings.
Yeah, and I still may be a bit radioactive from the barium.
Got them scrubbed , blown out, oiled up
Clemens
Has thanked: 501 times
Been thanked: 228 times
Post by Clemens »
I see no mirror like polished surface? Are you getting lazy, Steve?
Joking aside, it's quite amazing how nice the piston looks after all these miles and millions of explosions right above them.
1996 855 R,
2010 V70 D5,
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
So at this stage, could the pan be dropped and the pistons disconnected and pushed out the top ? I am just thinking that when I need to do this project myself that maybe I'd go ahead and do the rings/bearings too ( Not trying to foment job creep :) ).
1999 V70 GLT
