2004 S60R B8444S (V8) conversion (Previously : Exhaust Manifold removal.)
This topic is in the MVS Volvo Repair Database » 2004 S60R -- Yamaha V8 Conversion!
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
This looks like a burnout/ smoke show special. I saw an article in Hot Rod magazine a while back with an old style Austin Mini with LS V8 and roots blower. It was like this Volvo.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
"Rudezon" came about because beer. I remembered reading about it back when, like 6 years ago.
Looks like they hand-laid a one piece front clip. The only geographic reference I could find was Tiveden .
https://engineswapdepot.com/?p=16943
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
foggydogg wrote: 22 Feb 2021, 00:18 "Rudezon" came about because beer.
Rudezon came about as a result of boredom. The beer was just a mental lubricant.
Active
Past
RickHaleParker
Cameron Pyzewski"s B8444S swap.
Active
Past
RickHaleParker
Cameron Pyzewski getting daring ... B8444T. He is planning on 8 PSI of boost. With a static compression ratio of 10.4:1. The Effective Compression Ratio would be around 16:1. I might break out the slide rule later and pin down the ECR.
Active
Past
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Now that's gonna be interesting!
foggydogg
Post by foggydogg »
RickHaleParker wrote: 23 Mar 2021, 10:01 Cameron Pyzewski getting daring ... B8444T. He is planning on 8 PSI of boost. With a static compression ratio of 10.4:1. The Effective Compression Ratio would be around 16:1. I might break out the slide rule later and pin down the ECR.
Looks like they might need to put a little whump in the hood, too.
Plumbing will be interesting.
Back in the early days of NASCAR restrictor plate racing, the Elliot boys were rumored to have built a couple qualifying motors that approached 17:1. Good for about five laps at Talladega. The France family had a few thoughts on the matter.
foggydogg wrote: 23 Mar 2021, 13:21
Wow 17:1! ignition optional? Stretched head bolts? Must have been good racing fuel.
bmdubya1198
Nah, just kill the spark, they probably ran simply on compression at that point! :lol:
RickHaleParker
bmdubya1198 wrote: 23 Mar 2021, 16:33 Nah, just kill the spark, they probably ran simply on compression at that point! :lol:
What ever happened to Mazda's HCCI engine? ( Homogeneous Charge Compression Ignition )
The petrol engine that runs off compression ignition.
Active
Past
