2000 s80 check engine lighgt on
185cliftonst
- Year and Model: 2000 s80
have p1618 faujt in lead between aw 50-52 and motronic 4.3 (MIL Resquested) andp0751 shift solenoid a performance or stuck off which is giving me a check engine light,Would like to make repairs myself but have no idea where tp start.Help please !!!!
185cliftonst
got no response
185cliftonst
waiting for response from yesterday,s question
- Has thanked: 2656 times
- Been thanked: 1248 times
How many miles? How has the transmission been operating? How is the fluid color and smell? Any transmission repair/replace history?
viewtopic.php?t=55269
viewtopic.php?t=18091
viewtopic.php?t=50915
viewtopic.php?t=75224
185cliftonst
have 234,000 mi ,no trans.,odor ,fluid looks good,trans . shifting not as it show
- RickHaleParker
- Been thanked: 958 times
TCM-000B ( P0751 ) Shift solenoid S1. Hydraulic fault
Possible source
Possible source
- Glycol in the transmission fluid.
The hydraulic valve for solenoid S1 has stuck in the open or closed position
Defective control system (the solenoid binds or is stuck)
Internal leakage in the transmission
Warn or damaged clutch driven plates in the transmission.
- SuperHerman
- Been thanked: 207 times
My thoughts going off what RickHaleParker states:
Glycol contamination - check both fluids tranny and coolant. Have an engine coolant pressure test. If the system is compromised this should confirm. Some shops rent pressure check tools.
Solenoid and internal leakage in transmission - this sounds most likely a valve body issue. At your miles it would not be a surprise, but I am uncertain what transmission you have in your car. Also what scanner are you using?
As your fluid is visibly looking good I would discount worn clutch plates - a history of black fluid is what one would expect.
