Big Oil Leak front of 2.5T - Two cam seals and front crank seal - Any other seals ?
I finally got everything done. I did cleaned up the PCV system first and then installed junk yard VVT gear. So far no leak. Will see how long it last. I did install new cam seals. I looked in to the Volvo cam locking tool and did not care for it. I made my own tool and it worked great.
Waid
Waid
- Been thanked: 504 times
Haha,
Very nice tool you made!
On the other forum, someone posted a home-made tool DIY.
NOTE: do NOT use Aluminum, it will break as the DIYer, use steel:
https://volvoforums.com/forum/general-v ... ion-38396/
cn90 wrote: 27 Nov 2019, 18:25 I am re-posting the photo from the other forum.
I seriously doubt even steel flat stock would work with over 85 ft-lbs of torque. I made mine out of tool steel on lathe and then milled the slots. I did not even need the bolt to hold in place since I could not find 7mm bolt anywhere.
Waid
Stilltrying2
- Year and Model: 2001 S40
Read about the glove test and tried it, but - the glove was instantly sucked down into the oil spout ! Below is what I was able to pull out of the top of the engine
Replaced all the Oil Trap Box + hoses, etc.
Oil filter 1st oil change after the fix and then about a year later !
Big difference :>
Big difference :>
- 1 Oil Trap Box - Glove Trick.JPG (156.75 KiB) Viewed 4553 times
I would almost guarantee the reason your cam seals are leaking is due to a clogged oil trap. Replace the cam seals, timing belt (due to oil saturation), the oil trap and check to see if your charge air hose is oil saturated and replace that as well if it is. You will need that tool above along with a cam seal drift/installer. To make sure that get seated properly without damage.
- 9675 Views
Last post by tyguyc
- 12 Replies
- 4946 Views
Last post by ashgoldS60
- 11 Replies
- 9860 Views
Last post by xydki
- 22 Replies
- 10451 Views
Last post by ggleavitt
- 12 Replies
- 3481 Views
Last post by erikv11
