99' S70 weird coolant hose leak
Has thanked: 1505 times
Been thanked: 3818 times
Re: 99' S70 weird coolant hose leak
850 LPT wrote: 19 Mar 2021, 09:19 Wall thickness is my concern as well. And I am not really a fan of gluing things.
FCP sells new Nissens radiators for $110. I am tempted to go this route considering the fact that I don't know how old this radiator is and the car has close to 220k miles on it.
I think I drove my glued in radiator stopcock for about 3-4 years
800artfreed
Year and Model: 98 S70T5; 99 S70GLt
Been thanked: 26 times
Post by 800artfreed »
If your car has a turbo I found the inlet charge pipe to the Electronic Throttle Module (ETM) to the intercooler got in the way. You will be able to release the clamp where the pipe connects to the ETM. I used 1/4 inch sockets and extensions on a small 1/4" ratchet. This will allow you to remove the pipe. Why? Because this pipe prevents you from removing and replacing radiator from the top.
Check out this link, scroll towards the bottom. It has some pictures of the clamp and the reposition of the 7mm screw clamp head.
viewtopic.php?f=1&t=95746
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
850 LPT wrote: 19 Mar 2021, 06:50 This probably broke off at some point during PO's ownership and they somehow cobbled up a solution with this rubber piece.
The original is molded as part of the radiator.
If you decide to install a new Barb, use a plastic barb and JB Weld's PlasticWeld. The original JB Weld does not bond well to plastic. Let it cure for 24 - 48 hours.
From a MVS post in 2015.
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
Thanks for finding this, Rick. But I have since decided to install a new radiator which might still be the original one.
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
850 LPT
Post by 850 LPT »
I replaced the radiator yesterday and found something rather unusual. I have to say the PO got really creative. I am a little surprised it lasted this long since I have been driving the car for 2 years now, and who knows how long this was installed before I bought it.
Dirk
Is that a brass barb , JB welded into the hole on the radiator?
850 LPT
Post by 850 LPT »
abscate wrote: 04 Apr 2021, 07:03 Is that a brass barb , JB welded into the hole on the radiator?
No, it's a regular tire valve. Actual valve part removed.
