Hy Buddies,
I have to plane to rebuild all my front suspension. But i don't know which spring i should get. On VWSParts, the reference is 354 66 41.
? N° 1 : Which trade do you advice me ? Does the LESJOFORS trade speak to someone ?
? N° 2 : Where does this part goes on, engine bay side, to the top of the "Suspension strut Support Bearing Front axle upper" ?
As i 'm looking for advices, if someone wants to advice me with trade well known and efficients parts, just fill the excel bard following the link.
Many many thanks, Boys !
Manov
850 Suspension spring Front axle
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I have had good luck so far using Lesjofors spring on the rear of my '97 855... I wrote up a short description here:
viewtopic.php?f=1&t=95813&p=560572#p560572
- Has thanked: 987 times
- Been thanked: 1075 times
This guide is for later models, but the main parts are the same for suspension. viewtopic.php?t=91985
The 1034503 washer goes on top of the foam cushion.
Good luck.
Good luck.
Azik09
- Year and Model: S70 T5, 1997
- Has thanked: 2 times
- Been thanked: 31 times
I needed to raise front of my car and I installed springs from diesel (used). Here's result:
Picture for question 2, see pos.13
If my English is bad, please correct me
Those are the nice chiral Columba wheels! ( there are left and right hand versions)Azik09 wrote: 02 May 2021, 13:31 I nedded to raise front of my car and I installed springs from diesel (used). Here's result:IMG_20210502_221926.jpg
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 673 times
- Been thanked: 163 times
Hy Azik09Azik09 wrote: 02 May 2021, 13:31 I nedded to raise front of my car and I installed springs from diesel (used). Here's result:IMG_20210502_221926.jpg
I need to rebuild my front suspension. The issue with these diesel springs models is that they are too strong, to me, impression the wheels dance on the top of the suspension. To me, defintly not a good idea. Again : to me. And your english ik okay to me.
I have a question guys, i don't understand what these boarded references are for. Which springs shall i order ?
Here is the whole list, board © VOLVO - VPWS
https://www.volvopartswebstore.com/prod ... evel=24662
Manov
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
I was incredulous when I read this, but yes , it's true! Now that I know these weren't offered in bright silver they'll be easy to spot. I wonder if they are as ductile as the standard ones, or if they took the alloy up a notch.
abscate wrote: 04 May 2021, 04:55Those are the nice chiral Columba wheels! ( there are left and right hand versions)Azik09 wrote: 02 May 2021, 13:31 I nedded to raise front of my car and I installed springs from diesel (used). Here's result:IMG_20210502_221926.jpg
- X70_sportstyling_FR_GB_NL_DE.png (195.02 KiB) Viewed 1212 times
Azik09
I was afraid these diesel springs will be too hard, but they are not! Much softer than stock lowered T5 springs.manovlov wrote: The issue with these diesel springs models is that they are too strong, to me, impression the wheels dance on the top of the suspension.
