suspension --Front Upper Spring Seat
adrian22
Year and Model: s60 2006
Post by adrian22 »
volvo 2005 xc70
do I need to compress the springs in order to replace the broken Front Upper Spring Seat?
Or I can just unscrew the 3 screws to remove metal cover on the top of the strut?
adrian22
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
You need to take the entire strut out and compress the spring before replacing any of those parts.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Use good quality spring compressors
You need to compress the spring until the spring seat comes loose. The spring is under tremendous force when compressed. You don't want to see your face or arm fly away
Don't buy anything else but Sachs or Volvo spring seat. All others will crack in 6 months
The second video only shows how powerful the spring is when it's compressed, The guy used some cheap compressor and the compressor plate slipped off the spring. Plus they compressed the spring inside the car, on Volvo the strut has to be removed from the car.
IdahoBob
Year and Model: XC70 02, 04 & 08
Has thanked: 1 time
Been thanked: 4 times
Post by IdahoBob »
Someone please explain how to remove the strut before compressing the spring. I've done 4 of these now, and had to compress the spring to get the strut off (and back on), all four times. I strongly agree that you need to use quality tools that have a firm grip on the spring and the seat (the one that's welded on as part of the shock). I now use 4 spring compressors (2 sets) when squeezing the spring down. The last time I did it with 2 (one set), one of them slipped off, the spring escaped faster than my brain could process the image of it coming loose. It shot across the garage, bounced off the garage door and took out the rear window on the tailgate. That would have really hurt if I'd been between the spring and the door. Also, if you're replacing the rubber on top, consider how soon you want to do this all over again...maybe replace the shocks now also, as long as you have the whole thing apart?
Idaho Bob
67, 71, 85, 98 wagons (sold)
78 coupe (gave to mechanic, thanks!)
02, 04 (X2) & 08 XC70's
before that: 67 Sunbeam, several pre-68 VW's, '41 Buick, '42 Ford Jeep, and some boring stuff
Rattnalle
Post by Rattnalle »
You take three nuts off at the top and three bolts at the bottom and lift the thing out. I haven't had too much trouble doing this any of the four or five times I've done it.
Has thanked: 1610 times
Been thanked: 4065 times
Clarification
You remove the strut , spring, bearing assembly from the car, then compress and remove the spring. The three M8 nuts on top of the tower are the only thing you remove to remove the assembly from the car.
Rattnalle
Post by Rattnalle »
abscate wrote: 21 Dec 2017, 00:49 Clarification
Plus a few bolts at the bottom. To remove it that is.
But I agree that nothing else at the top should be touched before the spring is compressed.
oragex
Post by oragex »
@ Idahobob as mentioned on Volvo cars, along with Japanese cars and perhaps other brands, the strut rod is fully extended and keeps the spring under pressure when these are not installed yet in the car. Two safety bolts screwed on the strut rod keep the spring compressed at all times. This is why we need first to transfer the spring pressure to the spring compressor, before removing the two upper safety bolts. If the two safety bolts are removed without a spring compressor, the spring will pop out will high force and wound the worker (or worse). Same happens if someone would remove the safety bolts while the strut is still installed on the car: the spring will blow like an airbag and will damage other parts around.
There are videos on Youtube with the strut removal and spring compression. I found the hardest part to be undoing the end link at the strut. This bolt is tight and a quality torx socket is needed to keep it from spinning.
@ adrian for the metal plate -the strut mount bearing - the good parts are from Lemforder and Ina
