Engine self-destruct
- Been thanked: 504 times
In wonder if this is similar to the infamous "burned valve" issue we see in P80 cars (1993-1997 850, 1998-200 s70, V70 etc.)...Most commonly cylinder #3...
- kcodyjr
- Year and Model: 2006 S60 2.5T AWD
- Has thanked: 17 times
- Been thanked: 23 times
If you had bottom end damage, you wouldn't be asking about it. You'd be diving for cover and tightening your helmet.
If you have piston damage, you'll have zero compression, but you'll see that with the boroscope.
+1 compression test is next. If it's down, pull the head, strip it, send it out to have the valve seats lapped, and when you put it back together, replace any damaged valves.
5 others that came and went
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
research says they fitted the faulty engine killing banjo bolts from 2005 2.5ltr, so my 2001 2.4ltr should be safe? its going to be a while until i can remove and check it.
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
With the latest banjo bolt design it looks like the retaining pin is held in place with a through hole crosswise in the bolt. I believe this bolt has 2014 on the head if you want(can) to check which banjo design currently installed in the manifold.darylrobert wrote: 05 Jun 2021, 03:07 research says they fitted the faulty engine killing banjo bolts from 2005 2.5ltr, so my 2001 2.4ltr should be safe? its going to be a while until i can remove and check it.
- DonnVa
- Year and Model: 2005 XC70
- Has thanked: 21 times
- Been thanked: 61 times
Well damn, when I did my PCV last summer, mine was the old style and all I did was clean it out w/ some carb cleaner. I already had an alternator pulley and decoupler tool in my FCP cart. I just added the new banjo bolt. I should be able to get to it okay w/ the alternator out. Pulley job just got extended.
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
Zolll
- Year and Model: 2004 XC70
- Has thanked: 2 times
Good for you.. I wish I would've known about the stupid bolt back when I replaced my PCV parts years ago..DonnVa wrote: 05 Jun 2021, 16:01 Well damn, when I did my PCV last summer, mine was the old style and all I did was clean it out w/ some carb cleaner. I already had an alternator pulley and decoupler tool in my FCP cart. I just added the new banjo bolt. I should be able to get to it okay w/ the alternator out. Pulley job just got extended.
Anyone knows it I can just disconnect the exhaust manifold and pull the head out or should I also remove the turbo?
- 1647 Views
Last post by user17600
- 440 Views
Last post by mecheng
- 1274 Views
Last post by Ozark Lee
- 1178 Views
Last post by precopster
- 17 Replies
- 8567 Views
