There are very few instances where a high side pressure reading is really necessary to diagnose and repair the system. The only time it would be helpful is if there is some sort of obstruction which would normally occur at the orifice tube.
If the orifice tube is clogged then there are other problems, like the compressor failing internally.
As far as the adapter goes, I think it is the same as the R-12 to R-134A conversion adapter but that is just from looking at the fitting. I've never had a need to try it.
Where is the High-Side Service Port Located?
- Year and Model: Many Volvos
- Been thanked: 76 times
mattwebb502
- Year and Model: 855R, 1996
I've always watched both sides to diagnose.
IMO the high side can be revealing. Not always, but I prefer to watch both.
I'm not sure that the thread size is R-12 ... it measures 3/8" peak to peak. Isn't r12 1/4"?
Sorry... it's been a while and I don't have any gauges, fittings, etc anymore for me to go on.
Edit: I think you're right. 3/8" thread size / 3/16" flare = typical r12 high side.
adapter--
https://www.google.com/shopping/product ... CGEQ8wIwAw
thanks.
adapter--
thanks.
- 1996 855R
- 1997 855GLT
- 1975 Fiat 124
- 1997 855GLT
- 1975 Fiat 124
rjschuster
- Year and Model: 1999 v70r turbo awd
anyone know where [ or if it has one ] the high pressure ac port is on a 2000 mk1 v70r
thx in advance
thx in advance
- Has thanked: 1611 times
- Been thanked: 4075 times
The P80 platform (1992-2000) does not have a high pressure port on the ACrjschuster wrote: 30 Jun 2021, 05:22 anyone know where [ or if it has one ] the high pressure ac port is on a 2000 mk1 v70r
thx in advance
You can monitor the high side pressure three ways
1. VIDA
B. Decent scan tool with Volvo software like AUTEL series
iii. Resistance measurements on the high pressure switch behind the right side headlight on the AC manifold
- 5271 Views
Last post by mpchicago
- 2377 Views
Last post by rickyberetired
- 404 Views
- 887 Views
Last post by kahl
- 1051 Views
