850 Tool question
manovlov
Has thanked: 620 times
Been thanked: 143 times
850 Tool question
Post by manovlov »
Hy Buddies,
I have a question about tools. I've got an issue to unplug the AAC sensor, this one : the screws are in a bad shape, i thrown WD 40 for the night. Hum ? When i will succeed in unscrew these "bolts", i will replace them by 6 pans ones.
By the way, i've seen somewhere something like WD40 to help to unscrew bolts, but the composition was made with a little add of kerosene which seems to be better than WC40. Does it speak to someone ?
AAC Sensor.jpg (58.09 KiB) Viewed 740 times
The question :
i need to buy good tools. What should i get between these two ones :
facom 1.jpg (53.95 KiB) Viewed 741 times
Facom 2.jpg (55.91 KiB) Viewed 740 times
Manov
Has thanked: 1850 times
Been thanked: 1712 times
Facom make good tools. Either are good, but I prefer the older style as you can add a little piece of pipe to get more leverage. The 'T' type with the plastic may be able to do that but the plastic can crack.
As for WD-40, probably just as well peeing on the bolts. More likely to help remove the rust. Not sure what brands are out there in Europe anymore. Many years ago we had one called Plus-Gas. I think it was out of Sweden or Germany. Worked really well. Over here I use Liquid Wrench or PB Blaster.
Good luck undoing those bolts.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
For troublesome small bolts, there is also a simple thing called an impact screwdriver. You can install any kind of bit for allen, torx, screws, etc. It's a small cylinder you hold and smack the end with a hammer. It drives the bit into the screw or bolt so it doesn't slip, while turning it just a hair. A few smacks with that and it usually backs out.
Has thanked: 292 times
Been thanked: 765 times
The T-handle will be much more convenient for everyday use, but the L-handle will be more durable and fit into tight spaces better. Best choice of all is a torx socket set, in my opinion.
I agree WD-40 is useless as a penetrant. You can mix 50% acetone and 50% ATF (automatic transmission fluid) for a superb DIY penetrant. Shake vigorously to create an emulsion then apply with a plastic eye dropper.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
ATF and acetone! You must have grown up on a farm Erik.
I'll mention a few more esoteric tricks. One of them is lightly sharpening your torx/allen bit on a bench grinder while spinning it, to create a burr on the end, which is super hard and digs into the inside of the recess.
The other trick, which I haven't tried yet, is valve lapping compound on the bit, so the abrasive particles dig in and increase the grip inside the fastener. I'm dying to try this one.
manovlov
Post by manovlov »
Hy Buddies,
Ok, i keep this option :
I also will DIY my ATF / Acertone mix.
Thanks to all of you for the good advices.
Manov
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
I've got all three types of the tools shown above because they each have their moment when they are the correct tool for the job (plastic handled torx, key torx, and impact screwdriver), all inexpensive Harbor Freight versions (for those in France, Harbor Freight is a low cost tool importer like the Leroy Merlin / Dexter version in France).
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
There is a good product available in Europe called deblock oil (i think by innotec). It works, a mechanic I know swears by it. It is a lazy man's alternative to ATF and Acetone.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
I recommed to get a Knipex Cobra pipewrench (knipex 8701250 for example). They are absolutely great, hard teeth and good bite. I have used mine to open a lot of damaged and or rusted bolts on my 850. Great to have as a fallback option and in limited space.
850 T5-R '95 auto Image
Year and Model: 2001 V70
Been thanked: 1001 times
Post by volvolugnut »
manovlov wrote: 23 Jul 2021, 23:10 Hy Buddies,
Manov
I have used this type impact tool with surprising results many times. It even works on straight and Phillips head screws.
Added comment: This tool has a 3/8 drive and with some adapters can be used with your 3/8 (or other size) sockets.
