Greetings from NZ - 1977 264GL Barn Find project
volvo264
Year and Model: 1977 264 GL B27E
Been thanked: 3 times
Post by volvo264 »
HI Folks
Greetings from NZ
I found a 264GL B27E summer 2017 and started a slow process of restoring it when I get time. Its a stop start progress and looking for advices and tips. Some pic below.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Cool project!
Good luck!
BMW 540i 2002
S70 Base 2000
volvo264
Post by volvo264 »
kallekula wrote: 23 Aug 2021, 08:36 Cool project!..
Thanks . i am trying to restore any parts that is salvageable and documenting as I go . So far panels are in good shape and engine is good pretty condition 234,000 km. These k-jet do not like sitting idle ... It was in a barn for 17 years . Some of the Upholstery faded but not too damaged. Definitely going to install new underlay and vibration/soundproofing layer. More pic below
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
Fish oil...huh! I've never seen that before. Does it all wash off with soap and water and do you degrease it?
volvo264
Post by volvo264 »
BlackBart wrote: 26 Aug 2021, 12:02 Fish oil...huh! I've never seen that before. Does it all wash off with soap and water and do you degrease it?
Its something we do a here in NZ and Australia.. Its does protects the sheet , penetrates well and prevents rust forming. These Fish oils are deodorised, long lasting, rust inhibiting coating . You can get them in local auto shops over here .
https://www.repco.co.nz/en/car-care-pan ... p/A1221672
On the steel panels, this is the process I use
    Strip to bear metal
      Sand using Metal sand 360/ , them 800
        Add 1 part white vinegar+ 4 part water and apply on bear metal & rub the surface.
          surface rust turns as rust powder and rust area become black. ( after 30minutes)
            Wipe with water and dry with hand towel then air blower
              Apply Light 1 layer of fish oil. ( do this during winter time)
                Leave it couple of months ( cover the car , preferable in garage)
                  Inspect and wipe with Methanol spirit . If you see rust forming apply the vinegar treatment
                    Apply POR 15 Rust Preventive Paint to seal it permanently https://por15.com/
                      Then do your normal 2k prime, body filler, sanding and then finish coat...etc
                      On panel cavities you can apply the fish oil or ATF33 ( RED/PINK mineral AT Fluid) to keep moisture out etc... ATF33 is for the BW35/55 gearbox & power steering fluid (ATF TYPE G)
                      These are old school method, time consuming but I am not in a hurry. I have seen may poorly restored car panels start rusting after 2-3 years.
                      For underbody , the car already had a good Bituman rubbery coating, but i water blasted, air dried and applied another fresh coat . These steps should give a good seal underbody and for the panel before painting from rusting.
