Scraping / Tapping 08 S60 2.5T
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Re: Scraping / Tapping 08 S60 2.5T
Post by vtl »
That noise is coming from the worn VVT hub. Most certainly it is.
08s60
Year and Model: 2008 S60
Post by 08s60 »
vtl wrote: 09 Sep 2021, 12:26 That noise is coming from the worn VVT hub. Most certainly it is.
What would you suggest? Replace the VVT solenoids?
vtl
Post by vtl »
08s60 wrote: 09 Sep 2021, 15:28 What would you suggest? Replace the VVT solenoids?
I would suggest a proper diagnostics before throwing any parts. Especially anything VVT, because they tend to be expensive.
VVT is not moving angles while the engine is idling, solenoid shouldn't affect anything.
08s60
Post by 08s60 »
We found out what the scraping/tapping was.
The water pump was coming apart. It came apart on my wife today as she was driving. Low coolant light came on, within a minute as she was decelerating there was a pop, and the car died.
The water pump blew apart and shredded the timing belt…so I suppose the motor is junk.
She didn’t run it hot and nothing is being impacted when the starter spins. She tried it before calling me…so since I knew what damage was done was done I spun it myself to hear it.
These are interference engines correct?
Blacklab467
Year and Model: 2007 xc 70
Been thanked: 263 times
Post by Blacklab467 »
Yes but you might get lucky depending on when the timing belt got shred. Others may chime in with advise on what to check next but all might not be lost. Depending on your mechanical ability you may be able to resolve this by taking a compression test and taking the head off. Not a huge deal.....maybe.
2003 XC 70 (sold)
vtl
Post by vtl »
At least 2 valves are bent, 1 piston, connecting rod bearing and cylinder sleeve received some damage. A replacement engine could be cheaper than the repair.
08s60
Post by 08s60 »
Here are some pics of said car. Has been really well maintained (with the exception of water pump failure) and the cleanliness of the car speaks for itself. What do you guys think it’s worth as is?
DonnVa
Has thanked: 21 times
Been thanked: 60 times
Post by DonnVa »
That’s a good looking car! It deserves an engine transplant. 😉
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
Has thanked: 1503 times
Been thanked: 3817 times
It’s a $500-700 project at best. It’s beyond economical repair for a driver, so you really market will only be scrap or someone who can take it in with the head swap knowledge.
Once its a non runner, its value is destroyed by the fact that you cannot assess all the other drivetrain components so the buyer has to take all those potential costs into account.
vtl
Post by vtl »
For comparison, 2005 XC70 w/ 265k and original leather:
