Scraping / Tapping 08 S60 2.5T
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
Re: Scraping / Tapping 08 S60 2.5T
That noise is coming from the worn VVT hub. Most certainly it is.
vtl
I would suggest a proper diagnostics before throwing any parts. Especially anything VVT, because they tend to be expensive.
VVT is not moving angles while the engine is idling, solenoid shouldn't affect anything.
08s60
- Year and Model: 2008 S60
We found out what the scraping/tapping was.
The water pump was coming apart. It came apart on my wife today as she was driving. Low coolant light came on, within a minute as she was decelerating there was a pop, and the car died.
The water pump blew apart and shredded the timing belt…so I suppose the motor is junk.
She didn’t run it hot and nothing is being impacted when the starter spins. She tried it before calling me…so since I knew what damage was done was done I spun it myself to hear it.
These are interference engines correct?
- Blacklab467
- Year and Model: 2007 xc 70
- Been thanked: 263 times
Yes but you might get lucky depending on when the timing belt got shred. Others may chime in with advise on what to check next but all might not be lost. Depending on your mechanical ability you may be able to resolve this by taking a compression test and taking the head off. Not a huge deal.....maybe.
2003 XC 70 (sold)
- DonnVa
- Has thanked: 21 times
- Been thanked: 60 times
That’s a good looking car! It deserves an engine transplant.
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
- Has thanked: 1505 times
- Been thanked: 3818 times
It’s a $500-700 project at best. It’s beyond economical repair for a driver, so you really market will only be scrap or someone who can take it in with the head swap knowledge.
Once its a non runner, its value is destroyed by the fact that you cannot assess all the other drivetrain components so the buyer has to take all those potential costs into account.
