ATF change out
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Re: ATF change out
Post by vtl »
Mr. Detail wrote: 15 Sep 2021, 07:39 vtl, after removing the ATF plug is there a aluminum crush washer that needs replacement or can I re-use the old one?
Yes, a regular washer. Flip it over, can reuse one more time, then replace.
I've got a few dozens of these: https://www.fcpeuro.com/products/volvo- ... v50-v70-xc
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 151 times
Been thanked: 4 times
Post by Mr. Detail »
vtl, the last question I promise.
After removing the ATF drain plug, how much fluid do I allow to come out at a time? say 2 quarts and then re-plug it?
I am not sure since the engine is not running how much fluid drains out at a time.
Been thanked: 472 times
Post by cn90 »
- I re-use the washers all the time but here is the trick: keep it in the same orientation.
The drain bolt (whether engine oil change or ATF change) creates a distinct dent on the washer.
If you keep it in the same orientation ---> no leak.
If you flip it around, chances are---> leak!
- I posted these washers photo in forum...
Post by cn90 »
I posted BMW washers pics here...
https://www.bimmerfest.com/threads/re-u ... er.983316/
And 1998 Volvo V70 pics here:
viewtopic.php?t=42989
vtl
Post by vtl »
Mr. Detail wrote: 16 Sep 2021, 05:47 After removing the ATF drain plug, how much fluid do I allow to come out at a time? say 2 quarts and then re-plug it?
Drain everything. About 3-3.5 quarts will come out. Measure in a marked milk jug, refill the same amount.
ignatz
Year and Model: 2006 S60 t5m
Has thanked: 17 times
Been thanked: 33 times
Post by ignatz »
I use this laboratory gadget. I can't believe I didn't break it yet!
Also, to get an accurate reading, you should let the drained oil to cool down to 60 deg F.
But I get a good ballpark of what came out.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
vtl
Post by vtl »
Made in USA, scale is in milliliters (1/1000th of 1.057 quart), "Approximate volumes" - America does not believe in metric system =)
Mr. Detail
[/quote]
[/quote]
VTL, when I re-fill the same amount (3-3.5 qts) should the plug be re-inserted first or does the plug still stay removed?
I will assume that the plug stays out so the fresh 3-3.5 qts will force out more dirty ATF.
Sorry, I am an engineer and I like details. :idea:
vtl
Post by vtl »
Bolt is fully screwed in, otherwise you will loose all of your new ATF :)
Mr. Detail
but then how do I get the other 9-10 dirty quarts out?
