Hello, my 2000 V70 NA appears to have the newer P2 oil cooler with the short rubber hoses and worm clamps. I'm at 200k miles and doing a coolant flush. Is it recommended to proactively replace these hoses? Has anyone had problems with them?
FCP says they're part number 30676906 for right / upper / inlet and 30713304 for left / lower / return. VolvoPartsWebStore and Tasca say the inlet uses part 31439470 (same shape) and the return is discontinued. Maybe they're going out of stock so I should try to get them from FCP now.
Proactively replace oil cooler lines?
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
are the hoses soft. volvo used the Oetiker clamps for those to avoid the overtightening i see in your pic. If its not leaking leave it alone, but if your stressing about it just change it.
- Has thanked: 1611 times
- Been thanked: 4072 times
Easy hose to spec if we know the ID. The shape isn’t complex, so a straight piece of hose will do.
Definitely use oetikers on those hoses, I wrapped mine with exhaust wrap to protect them
I have to change out my bad clamps on mine, good reminder from this thread
I’m not sure we have ever had a failure in these. If you watch your coolant levels you will catch a seep. I don’t think Volvo brand hoses ever burst.
- Has thanked: 987 times
- Been thanked: 1078 times
Those steel tubes have quite a lot of corrosion. Anyone know how thick they are? If only about 1 mm thick, I suggest changing the tubes for long term peace of mind.
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
The PO of my P2 put on new oil cooler hoses using cheap worm clamps. They also didn't wrap heat shield around them.
With the hoses removed I just had to wrap them with exhaust shield and use high quality Norma brand clamps:
https://www.amazon.com/NORMA-0136670402 ... B06Y2BPTTZ
https://www.amazon.com/Design-Engineeri ... r=1-4&th=1
I used that same wrap but my clamps were crappy. I’ve ordered the Normas which are OE Volvo
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Spray with Noxudol 700, it will prevent any further rust for the remaining life of the car.volvolugnut wrote: 22 Sep 2021, 08:36 Those steel tubes have quite a lot of corrosion. Anyone know how thick they are? If only about 1 mm thick, I suggest changing the tubes for long term peace of mind.
Measured the metal pipes on the cooler today
15mm OD
There is a 17mm flare in them so a 15mm ID hose is needed to seal
15mm OD
