Collar sleeve damage
renegade420
- Year and Model: 2006 s60r
- Been thanked: 3 times
Looking for a quick opinion. While have a tough time removing the collar sleeve, it was slightly damaged in the process from the grips when pulling it out. Is this damage too significant to try and reinstall and use?
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
It won’t hurt anything, just make sure it slides on and off the bevel gear splines. If it binds, file the collar sleeve splines with a small triangular profile file so it slides on easy, also check the outside machined surface of the colllar and make sure you didn’t scratch it where the seal rides.
2003 XC 70 (sold)
- Has thanked: 987 times
- Been thanked: 1076 times
My opinion: Clean up the slight damage with a small file. Assure the parts slide together OK. There is not enough damage here to worry about.
renegade420
Thank you both for the replies. I was thinking the same thing but wanted another opinion. The file idea was already floating around in my head. Thanks again!!
- Been thanked: 4071 times
Clean it up and use. Smart for checking. Many brains on a problem is good.
- 4328 Views
Last post by darrylrobert
- 640 Views
- 36 Replies
- 19191 Views
Last post by ggleavitt
- 611 Views
Last post by neilmullen
- 16 Replies
- 4134 Views
Last post by Chili58
