Actually having lunch first, then we begin!
On the agenda----
New belt, and water pump, and fix exhaust camshaft seal leak....it's a big one.
I'm being told (forum thread, youtube vids, S70 Paul and V70 Shane red wagon squadron) to be careful with the following:
marking the cams, securing cams with zip ties, and having crank at TDC...
Getting belt over the crank pulley....
And taking plugs out, and hand cranking the motor to make sure there is no interference....
It seems you get one shot to get everything in position before you pull the pin on the tensioner....
Anything else to be on the lookout for? Thanks in advance, and HERE WE GO------
Big Al
1998 V70 GLT FWD timing belt change...starting now!
Sufbug
- Year and Model: 1998 V70
- Has thanked: 2 times
- Been thanked: 2 times
Some pics to get us started .....
1998 V70 wagon / 244,013 miles / purchased 9-25-2020
2016 Cadillac CTS4 / might be selling this
1979 trans am 400ci / 4 speed / t-tops / not selling this
Sufbug
And we are in the air! --- gonna do the brakes as well and an oil change-and some other goodies!
Sufbug
Move coolant reservoir
Remove timing covers
Move tensioner with 1/2 to 3/4 adapter
Pin tensioner in open position ( Allen wrench)
Remove access belt.
17:39 10/9/2021. Start time approx 17:00
Remove access belt.
Sufbug
Ok, I found the cam timing marks.
Having trouble finding the top dead center marks on the crank pulley.
Help anyone?
Help anyone?
- Nevada1906
- Year and Model: 1995 850 Turbo
- Been thanked: 30 times
If it were me, I'd hose the whole front of the engine down with engine degreaser and brake cleaner once you change those cam seals.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
- Nevada1906
Sufbug wrote: 09 Oct 2021, 17:35 Ok, I found the cam timing marks.
Help anyone?
On the timing belt pulley, there's a tooth with a notch on either side. The red lines indicate the notches on both sides of the #1 TDC tooth. It looks like this:
There's also a raised bar on the pulley mount, which is in line with the TDC notch. It's the silver part in the picture.
Hope this helps.
- Been thanked: 4069 times
The timing mark on the crank pulley is notTDC , it’s a non interference markSufbug wrote: 09 Oct 2021, 17:35 Ok, I found the cam timing marks.
Help anyone?
It can be either the scribed lines or the notches in the inboard side of the pulley teeth. You have to look for both on an old car that may have been reworked
If you set the cams to the angled mark the crank will be close enough to see the marks.
- Nevada1906
abscate wrote: 09 Oct 2021, 18:04The timing mark on the crank pulley is notTDC , it’s a non interference markSufbug wrote: 09 Oct 2021, 17:35 Ok, I found the cam timing marks.
Help anyone?
Could you clarify? I'm pretty sure that's the mark for #1 TDC. It's not like there're any other marks on the pulley.
- 1090 Views
Last post by beigg
- 2706 Views
Last post by SuperHerman
- 1137 Views
Last post by lummert
- 2039 Views
Last post by alschnertz
- 5327 Views
Last post by jimmy57
