99 S70: removing manual shifter knob
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Couldn't find the pic with the shaft chucked up in the vice, the cup part number is 3502504
Pretty straightforward once it's on the bench, although I did need the medium-large hammer. Pick the correct size open end wrench for the shaft, put it against the bottom of the offending knob, and wail away.
Shrapnel warning, pieces will fly.
Has thanked: 1609 times
Been thanked: 4065 times
That’s a real deal 17mm Craftsman , not the current crap, isn’t it?
foggydogg
Post by foggydogg »
abscate wrote: 22 Oct 2021, 10:18 That’s a real deal 17mm Craftsman , not the current crap, isn’t it?
Yessir, although I have a set of the Other that stays in the car.
I used one of those to beat on (see above).
krenekj
Year and Model: Wife says too many
Has thanked: 2 times
Post by krenekj »
Thank you for the replies. It sounds like I can just twist the boot and pull it down, and that the knob needs to be pried/beaten off the shaft.
Would this method work: Bob's Your Uncle?
It would be great to not take out the mechanism as it's working fine.
Thanks.
93 240 Wagon
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
I'm not sure if that'll work on that style knob, but it might. I use that method for the -'98 style and it works very well.
