Couldn't find the pic with the shaft chucked up in the vice, the cup part number is 3502504
Pretty straightforward once it's on the bench, although I did need the medium-large hammer. Pick the correct size open end wrench for the shaft, put it against the bottom of the offending knob, and wail away.
Shrapnel warning, pieces will fly.
99 S70: removing manual shifter knob
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
- Been thanked: 4064 times
That’s a real deal 17mm Craftsman , not the current crap, isn’t it?
- foggydogg
Yessir, although I have a set of the Other that stays in the car.abscate wrote: 22 Oct 2021, 10:18 That’s a real deal 17mm Craftsman , not the current crap, isn’t it?
I used one of those to beat on (see above).
krenekj
- Year and Model: Wife says too many
- Has thanked: 2 times
Thank you for the replies. It sounds like I can just twist the boot and pull it down, and that the knob needs to be pried/beaten off the shaft.
Would this method work: Bob's Your Uncle?
It would be great to not take out the mechanism as it's working fine.
Thanks.
Thanks.
93 240 Wagon
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
- Has thanked: 316 times
- Been thanked: 531 times
I'm not sure if that'll work on that style knob, but it might. I use that method for the -'98 style and it works very well.
