Is it time for a new automatic gearbox ?
greffel
Year and Model: 2003 S60
Has thanked: 11 times
Been thanked: 7 times
Re: Is it time for a new automatic gearbox ?
Post by greffel »
Is there a spec for the Nm on the pinion nut?
First time I tightened it a little bit to hard and had to press everything apart again. Now I think I have it just right.
Polestar 2 - All electric daily driver :shock:
S60 2.5T AWD with a little bit more power :evil:
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
greffel wrote: 24 Oct 2021, 12:02 Is there a spec for the Nm on the pinion nut?
I can't find a torque spec for the pinion nut.
For the clearance spec, 1.3mm is within the spec range but from your photo I'm not sure how you measured it. The straight edge should be sitting flat across the thrust bearings and extending out past the mating surface of the case. The clearance to measure is between the case mating surface and the straight edge over the case surface, the same edge that's pressed flat on the thrust bearing. .
greffel
Post by greffel »
Meassued like this...
firstv70volvo
greffel wrote: 24 Oct 2021, 13:28 Meassued like this...
The straight edge should be vertical and the edge should be flat against the pinion gear thrust bearing rollers with the edge extending out beyond the case mating surface. The measured clearance is between the case mating surface and the straight edge extending over the mating surface. The thrust roller bearings should be slightly higher than the case mating surface and that the clearance to measure.
From your photo it looks like the big end shaft bearing is still in place, it needs to be removed so you get to the thrust bearings and rest the edge on the thrust bearings.
Set the straight edge on edge and across as many of the shaft thrust bearings as possible so it's flat and extends beyond the case mating surface.
EC) Small windage pan installed Note selective sized washer behind diff bearring race for preload.jpg
Place straight edge across as many thrust roller bearings as possible and extend straight edge beyond case edge. Measure between case surface and straight edge.
greffel
Post by greffel »
First of all big thanks for your help :)
Now you lost me a little bit... the way I measured is without the bearing in your picture.
The measurement shows that the gear is 1.3mm lower then the case surface.
Should i measure with this bearing installed and see how muck higher the bearing is over the case ?
Without this bearing I get 1.3mm
firstv70volvo
greffel wrote: 24 Oct 2021, 15:03 First of all big thanks for your help :)
According to the ATSG manual you put the straight edge on top the thrust roller bearings so this bearing does need to be installed. The top of these roller bearings should be slightly above mating surface of the case by the spec amount.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
I'm late to the party, spent 4 days in the woods...
The gap:
I think the simplest course was to swap both assemblies as is. It's always a good idea to recheck the differential bearing preload when the transmission is half apart like that one. Need to do it only for the differential, which has taper bearings on both ends. Correcting a tiny bit of preload is much easier that replacing the cog, like you did.
greffel
Post by greffel »
Now the box is back together. for the second time.
Reviewing my photos I noticed that I forgot to do the indentations on the pinion nut :D
Measuring the right way I have 1.4mm so right in the middle of the spec I guess.
Now a little bit more coaching wanted...
The B5 spring in the valve body seams to be present in my old valve body. Pressing on it you can feel its spring loaded.
Do I really need to take of the pan on this box to verify the same ?
I want to clean the radiator before assembly. Is it enough to just pure new oil thru it or should I clean it in another way?
Also planning so do a little mini flush of the R box just to be super safe.
firstv70volvo
greffel wrote: 25 Oct 2021, 12:07 Now the box is back together. for the second time.
Measurement value looks good. Good thing you went back and peened the nut.
For the B5 spring and according to Sonnax Volvo didn't have the B5 spring for 2001 - MY2004 cars. Was your old valve body a replacement? If so any chance you have the original VB still around to check for a spring?
https://www.sonnax.com/parts/4194-reman ... valve-body
vtl
Post by vtl »
Also the whole transmission swap takes only twice longer than just the valve body swap. It is simply cheaper to remove the VB cover now and check that spring, while everything is freely accessible.
