Massive Oil Leak
Been thanked: 4065 times
I’ll guess you didn’t quite seat the cam sensor reluctor wheel on the VVT cam and it’s hitting the sensor. Does it sound like the worlds loudest mouse chewing on stuff?
A very close friend of mine did this once on a 1999 V70 T5 M56 in Nautic Blue
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
abscate wrote: 07 Nov 2021, 06:07 I’ll guess you didn’t quite seat the cam sensor reluctor wheel on the VVT cam and it’s hitting the sensor. Does it sound like the worlds loudest mouse chewing on stuff?
Yep. Sounded metal to metal.
Oka
Post by Oka »
May I ask what your friend did to solve this issue?
I’ll ask him next time I see him.
Ok, you removed the reluctor, the little metal cup that bolts to the back of the cam, and found that it seems to sit right in many positions but only goes in one way correctly. It will sit nice amd flush and square with respect to the cylinder head when right
Oka
Post by Oka »
abscate wrote: 11 Nov 2021, 03:25 I’ll ask him next time I see him.
The cap, I did right, am sure. My bad, it should ONLY fit one way.
Thanks
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
erikv11 wrote: 21 Aug 2021, 09:03 I had a leaky oil filter cup looked a lot like that unless it was really really tight. Tried replacing the gasket no go. I ended up getting a new one solved the problem, never figured out how the old one was bad.
That happened to me too. Must have been some small crack i couldnt see. Very odd
BMW 540i 2002
S70 Base 2000
Oka
Post by Oka »
Don't know what to check from here on.
TisMe
Year and Model: 2001 & 2004 XC70
Has thanked: 42 times
Been thanked: 17 times
Post by TisMe »
I would go ahead and pull that engine mount back off, and retrace your steps back toward to the far exhaust cam seal, then play with the reluctor wheel. Just for fun :) from the maintenance you listed, I don't see what else could make the described noise.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
TisMe wrote: 11 Nov 2021, 18:54 I would go ahead and pull that engine mount back off, and retrace your steps back toward to the far exhaust cam seal, then play with the reluctor wheel. Just for fun :) from the maintenance you listed, I don't see what else could make the described noise.
Retracing is a good approach, could very well be the motor mount itself.
WHen I lost a coil the engine made a knocking noise under load ( on 4 cyls) , turned out to be the motor mount.
The noise went away when the coil was replaced.
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
Oka wrote: 06 Nov 2021, 20:13 Finally finished and put everything back. Been busy with other things. Here are the work I did.
- Front crank seals, intake and exhaust side
- Water pump
- Timing belt, serpentine belt
- Timing belt tensioner
- PVC breather and oil trap
- Pulled down the oil pan and cleaned
- All o-rings in the area I worked
However, I connected the battery, started the car, and it sounded bad, like grinding teeth; I turned the car off right away.
What on earth could that have been?
Cheers
If you hear metal to metal type grinding noise when you started the car you should also hear something when turning the engine over manually. Take the spark plugs out to make it easier to turn over the engine manually from the crank pulley nut and with helper listen carefully for the sound, you should at least be able to pinpoint where the sound is coming from.
