Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
> When i did p2 my first 2 pin was always the same and now im getting random pin.
Was it always the right pin bytes?
blasaab
Year and Model: Volvo xc90/V50/144
Been thanked: 3 times
Post by blasaab »
On P2 I could see like 65 78 as first pin every time and T5luke told me first 2 pin was correct and finaly after several Times it was succesfull.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
blasaab wrote: 11 Nov 2021, 12:26 I dont know if im doing something wrong. When i did p2 my first 2 pin was always the same and now im getting random pin. Should i add resistor or ignition on? Does my reads looks ok?
The CEM is responding. I don't think turning the key on will make a difference.
I don't use terminating resistors on mine because the resistance at the OBD port proves the CEM is already terminated. The only time I use terminating resistors is on the bench. But that was with P2. Measure the resistance at the CAN pins of the OBDII connector and post the measurements.
You are having trouble cracking everything you try to crack. The common factor is the cracker hardware. Post some good quality pictures of your hardware. Maybe one of us can spot something.
Active
Past
vtl
Post by vtl »
blasaab wrote: 11 Nov 2021, 12:53 On P2 I could see like 65 78 as first pin every time and T5luke told me first 2 pin was correct and finaly after several Times it was succesfull.
Do you have current logs (for when it fails)?
RickHaleParker
vtl wrote: 11 Nov 2021, 18:57 Do you have current logs (for when it fails)?
Some of the fails might be due to low or weak voltages. There are a lot of people running around with a marginal battery. Somewhere down the line a battery voltage check might be a needed addition. The question would be at what voltage would one call it a no go.
Active
Past
vtl
Post by vtl »
RickHaleParker wrote: 11 Nov 2021, 20:13
The most recent commit (https://github.com/vtl/volvo-cem-cracke ... 5badd3b094) changed the way how the candidate is elected. I would guess, it may break some cases, though unintended.
RickHaleParker
vtl wrote: 11 Nov 2021, 20:25 The most recent commit (https://github.com/vtl/volvo-cem-cracke ... 5badd3b094) changed the way how the candidate is elected. I would guess, it may break some cases, though unintended.
The shortlist method appears to work better then the old algo.
I'm thinking some of the fails maybe electronics not code. I have seen some of mine fail to crack when the battery voltage got low. Cracked after bringing the battery charge and voltage back up.
Active
Past
vtl
Post by vtl »
RickHaleParker wrote: 11 Nov 2021, 20:54 The shortlist method appears to work better then the old algo.
I see that too, with CEMs/dumps I have in my lab.
RickHaleParker wrote: 11 Nov 2021, 20:54 I'm thinking some of the fails maybe electronics not code. I have seen some of mine fail to crack when the battery voltage got low. Cracked after bringing the battery charge and voltage back up.
Right. This thread confirmed it many times that the quality implementation is the key to success.
blasaab
Post by blasaab »
I can try on bench but dont have pinout for p1 cem
RickHaleParker
blasaab wrote: 12 Nov 2021, 13:05 I can try on bench but dont have pinout for p1 cem
Every last one of the V50 EWDs ( Electrical Wiring Diagrams ) are online ... in multiple languages. The EWDs have the connector pinouts. It is not straight forward but there is enough information that you can map out the pins. It will take some legwork.
4/56 is the CEM.
Schematic:
Connector:PIN
Example A:1 = Connector A : Pin #1
Connectors:
4/56A is connector A on the CEM.
4/56A:1 is pin #1 of connector A on the CEM.
Same goes for connector B, C, D, E, F, G, H
If you are looking to extract the dump file.
Active
Past
