The book of codes
SoDoWarts
Year and Model:
Post by SoDoWarts »
Howdy -- is there some resource out there that lists all the OBD codes for the C70 convertible 2000? Thank you!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2866 times
Been thanked: 1332 times
Post by matthew1 »
I can't remember if 2000 C70 was M4.3 or what, but start here. https://www.matthewsvolvosite.com/volvo ... 5-to-1998/
Also -> Amazon link
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
A 2000 C70 should be ME7.
RickHaleParker
Been thanked: 981 times
Post by RickHaleParker »
SoDoWarts wrote: 13 Nov 2021, 12:55 Howdy -- is there some resource out there that lists all the OBD codes for the C70 convertible 2000? Thank you!
VIDA.
Active
Past
RickHaleParker
Chuck W wrote: 13 Nov 2021, 13:13 A 2000 C70 should be ME7.
It is ME7 but that is the ECM only. He wants all the codes. There are 16 control modules on the 2000 C70.
Active
Past
Has thanked: 1614 times
Been thanked: 4078 times
For ECM codes all P0xxdx codes are SAE standard so they are preserved across makes.
Corrected below, thanks RHP
RickHaleParker
abscate wrote: 13 Nov 2021, 14:23 For ECM codes all P0xxx codes are SAE standard so they are preserved across makes.
x0xxx, x2xxx & x3400 - x3499 are SAE Generic.
1st digit identifies vehicle subsystem
  • P - POWERTRAIN
    C- CHASSIS
    B- BODY
    U- NETWORK
2nd digit identifies code type
  • 0, 2 - SAE Generic
    1- Manufacturer Specific
    3- SAE or Manufacturer Specific (Code Dependent)
    x3000-x3399 Manufacturer Specific
    x3400 - x3499 SAE Generic.
3rd Digit Identifies Specific Vehicle System
  • 0 - Fuel, Air Metering & Auxiliary Emission Controls0-
    1 - Fuel and Air Metering
    2 - Fuel and Air Metering
    3 - Ignition System or Misfire
    4 - Auxiliary Emission Controls
    5 - Vehicle Speed, Idle Control, and Auxiliary Inputs
    6 - Computer and Auxiliary Inputs
    7 - Transmission
    8 - Transmission
    9 - Transmission
    A- Hybrid Propulsion
    B-F SAE reserved for future use
4th and 5th digits identify the specific fault with the system. Too many to list here.
Active
Past
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
^ I never knew this. Very cool !
1999 V70 GLT
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
The internet is a good resource for identifying most fault codes. You do have to sort the meaningless results from the good information.
I’m pretty sure Denzel Washington made a movie on this topic
