The book of codes
- Has thanked: 2866 times
- Been thanked: 1332 times
I can't remember if 2000 C70 was M4.3 or what, but start here. https://www.matthewsvolvosite.com/volvo ... 5-to-1998/
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
A 2000 C70 should be ME7.
- RickHaleParker
- Been thanked: 981 times
VIDA.SoDoWarts wrote: 13 Nov 2021, 12:55 Howdy -- is there some resource out there that lists all the OBD codes for the C70 convertible 2000? Thank you!
Active
Past
Past
- RickHaleParker
It is ME7 but that is the ECM only. He wants all the codes. There are 16 control modules on the 2000 C70.
Active
Past
Past
- Has thanked: 1614 times
- Been thanked: 4078 times
For ECM codes all P0xxdx codes are SAE standard so they are preserved across makes.
Corrected below, thanks RHP
- RickHaleParker
x0xxx, x2xxx & x3400 - x3499 are SAE Generic.abscate wrote: 13 Nov 2021, 14:23 For ECM codes all P0xxx codes are SAE standard so they are preserved across makes.
1st digit identifies vehicle subsystem
- P - POWERTRAIN
C- CHASSIS
B- BODY
U- NETWORK
- 0, 2 - SAE Generic
1- Manufacturer Specific
3- SAE or Manufacturer Specific (Code Dependent)
x3000-x3399 Manufacturer Specific
x3400 - x3499 SAE Generic.
- 0 - Fuel, Air Metering & Auxiliary Emission Controls0-
1 - Fuel and Air Metering
2 - Fuel and Air Metering
3 - Ignition System or Misfire
4 - Auxiliary Emission Controls
5 - Vehicle Speed, Idle Control, and Auxiliary Inputs
6 - Computer and Auxiliary Inputs
7 - Transmission
8 - Transmission
9 - Transmission
A- Hybrid Propulsion
B-F SAE reserved for future use
Active
Past
Past
- Has thanked: 987 times
- Been thanked: 1078 times
The internet is a good resource for identifying most fault codes. You do have to sort the meaningless results from the good information.
I’m pretty sure Denzel Washington made a movie on this topic
- 1269 Views
Last post by mynoralvarez
- 2605 Views
Last post by tbonehemms
- 1904 Views
- 11 Replies
- 2887 Views
Last post by E Showell
- 8369 Views
Last post by BlackBart
